[GRASS-dev] [GRASS GIS] #344: TODO: move high priority incubated modules into main
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
before 6.4.0 we should move high priority incubated modules into main. For
replacements, if the svn-addons still has issues which makes it poorer
than the old version, we can call it "g.module2",
otherwise we replace. If still known to be beta-ware but still functional
we can add a G_warning() to the beginning of the module as an absolution.
Just having a quick look through
   https://trac.osgeo.org/grass/browser/grass-addons
Modules to consider:
d.frame.split?
r.colors.stddev?
r.viewshed
r.sun2+horizon
r.watershed2
v.buffer2
v.colors?
v.delaunay2
v.parallel2?
v.out.ascii.db -> v.out.ascii C code !!
r.pack rewrite using method similar to r.convert (#84) + tar.gzip?
put together a quick v.to.3d wrapper script?
others?/add?/remove?/replacement or "g.module2"?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by hamish):
Also, it may be useful to categorize "must-do"s as blocker bugs, or as
tasks:
Tasks TODO for 6.4.0:
https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&milestone=6.4.0&type=task&order=priority
realizing that pet-wishes and bugs require an interested & active
developer to remain high-priority. (note to self)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:1&gt;
Comment (by wolf):
Replying to [ticket:344 hamish]:
> v.buffer2
> v.parallel2?
Definitely! SoC 2008 project that is ready. Maybe some more testing is
needed. It works better than v.buffer (it actually works ;)) It contains
some fixes that we should consider putting into Vlib in develbranch_6.
> v.delaunay2
Another SoC 2008 project that is ready. Paul is the code production-
quality?
--Wolf
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:2&gt;
Changes (by pkelly):
* cc: mpavlovsky@gmail.com (added)
Comment:
Replying to [comment:2 wolf]:
> > v.delaunay2
quality?
Well I haven't *thoroughly* tested it, but Martin (the author) has, and
anyway I'm very confident about the quality of it. It is all in GRASS
style already and has even been indent'ed correctly. It needs some
copyright statements put into the source code though.
Ticket URL: <http://trac.osgeo.org/grass/ticket/344#comment:3&gt;
Comment (by neteler):
Given the feedback here, I suggest to actually replace v.buffer,
v.parallel and v.delaunay
with v.buffer2, v.parallel2, v.delaunay2 from Addons using the former
names.
Since all of the original modules are broken for larger maps, there is
little to lose.
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:4&gt;
Comment (by msieczka):
Replying to [comment:4 neteler]:
names.
+1. Working v.buffer is a must have.
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:5&gt;
Given the feedback here, it appears that r.viewshed is not yet ready for
release.
v.out.gps[babel] is pretty much ready to be activated, it just waits on
the v.out.ogr bugfix (#354). It does something necessary that gpsbabel and
the QGIS GPS plugin do not: automatically reproject to WGS84 LL.
Markus, thoughts about r.sun2 + r.horizon?
r.watershed.fast2 is still high on my list for testing+inclusion, but as
always deadlines distract...
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:6&gt;
r.sun2 + r.horizon are ready in my opiniom, I have made tests even with a
450Mpixels DEM and we fixed some memory issues for those large maps. I'll
take care of that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:7&gt;
names.
Done in 6.4.svn and 7. The old modules have been disactivated.
Please check and fix if necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:8&gt;
For easier maintenance, I have created:
http://grass.osgeo.org/wiki/GRASS_6.4_Feature_Plan
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:9&gt;
update:
r.sun2, r.horizon added.
v.buffer2, v.parallel2, v.delaunay2 added.
r.watershed.fast merged.
d.frame.split, r.colors.stddev, v.colors added.
v.out.gpsbabel added.
r.viewshed: code not ready yet?
TODO high priority:
  - v.out.ascii.db -> v.out.ascii C code
TODO lower priority:
  - r.pack rewrite using method similar to r.convert (#84) + tar.gzip
  - put together a quick v.to.3d wrapper script
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:10&gt;
Replying to [comment:10 hamish]:
> update:
No, see trac bug #390
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:11&gt;
  Priority: blocker | Milestone: 6.4.0
Changes (by hamish):
  * priority: major => blocker
Comment:
* r.pack: not for inclusion in GRASS 6.4. to prevent future confusion the
saved file format will not be formalized until the grass7 file format has
been. prototype script available in svn addons as r.pack2.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:12&gt;
done (for the purposes of reserving the namespace, enhancements may come
later):
  - v.to.3d prototype written by Martin
remaining TODO for this ticket:
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/344#comment:13&gt;
Comment (by martinl):
Replying to [comment:13 hamish]:
done in r34917. Please test it out...
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/344#comment:14&gt;
Comment (by mlennert):
Replying to [comment:14 martinl]:
In trunk, I get the following error during compile:
VERSION_NUMBER=7.0.svn
/home/mlennert/SRC/GRASS/grass_trunk/tools/g.html2man/g.html2man.py
/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
gnu/docs/html/v.out.ascii.html /home/mlennert/SRC/GRASS/grass_trunk/dist.
i486-pc-linux-gnu/man/man1/v.out.ascii.1
gnu/docs/html/v.out.ascii.html:90:0: Error ({'args': ()}): <o>
make: *** [/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
gnu/man/man1/v.out.ascii.1] Erreur 1
rm v.out.ascii.tmp.html
In devel6, I can compile, but I get a segmentation fault using NC demo
data and running:
v.out.ascii in=hospitals out=hospitals.ascii colu=NAME
but not with
v.out.ascii in=hospitals out=hospitals.ascii colu=PHONE
GRASS 6.4.svn (nc_spm_06):~ > v.info -c hospitals
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|OBJECTID
DOUBLE PRECISION|AREA
DOUBLE PRECISION|PERIMETER
INTEGER|HLS_
INTEGER|HLS_ID
CHARACTER|NAME
CHARACTER|ADDRESS
CHARACTER|CITY
CHARACTER|ZIP
CHARACTER|COUNTY
CHARACTER|PHONE
CHARACTER|CANCER
INTEGER|POLYGONID
DOUBLE PRECISION|SCALE
DOUBLE PRECISION|ANGLE
GRASS 6.4.svn (nc_spm_06):~ > v.db.connect -p hospitals
Vector map <hospitals@PERMANENT> is connected by:
layer <1> table <hospitals> in database
</home/mlennert/GRASS/DATA/nc_spm_06/PERMANENT/dbf/> through driver <dbf>
with key <cat>
Running
for col in `v.info -c hospitals | awk -F"|" '{print $2}'`; do echo $col;
v.out.ascii in=hospitals out=hospitals_$col colu=$col; done
gives segfaults with NAME and ADDRESS and "Illegal instruction" with CITY.
The same script on comm_colleges causes seg faults for the columns
ADDRESS1 and "Illegal instruction" on CC_NAME and ADDRESS2.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/344#comment:15&gt;
Fixed in r34924.
data and running:
strange no segfault here...
> but not with
also OK
with key <cat>
same...
everything OK
CITY. The same script on comm_colleges causes seg faults for the columns
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/344#comment:16&gt;
Martin:
great!
It works for me; I don't get any segfaults.
I notice that the column names are case sensitive; and could the column
check be moved before any output? and the error message should be like
"column <%s> not found" ?
GRASS64> v.out.ascii in=hospitals col=name,phone
ERROR: Column <name>: unsupported data type
697237.5638615|182012.65540056|1GRASS64>
cheers,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:17&gt;
Moritz: any chance to give a gdb backtrace?
http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:18&gt;
Replying to [comment:17 hamish]:
fixed in r34926 (6.4) r34927 (7.0).
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:19&gt;
