[GRASS-dev] [GRASS GIS] #3442: Able to select unitis in r.volume
Reporter: malicera | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
The module r.volume is a very powerfull tool, but the lack of control over
the units it produces its result and the lack of support of lon-lat units
limits its use.
I would like to have a way to indicate the units of the raster so the
program can use an apropiate unit to calculate the area to match the sum,
just as it is done when a surface calculation is required in the r.report.
I have an example where some volumes were calculated that would be nice to
do able to do with r.volume
https://gis.stackexchange.com/questions/258482/how-to-restore-a-scarp-
surface-grid-to-calculate-material-loss/259451#259451
Ticket URL: <https://trac.osgeo.org/grass/ticket/3442&gt;
  Priority: normal | Milestone: 7.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords: r.volume
Changes (by martinl):
* keywords: => r.volume
* component: Default => Raster
* milestone: => 7.4.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3442#comment:1&gt;
