[GRASS-dev] [GRASS GIS] #3444: v.concave.hull -script type definition for table column not compatible with PostgreSQL
PostgreSQL
Reporter: harrik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: 7.2.0
Keywords: v.concave.hull, PostgreSQL | CPU: Unspecified
Platform: Unspecified |
Very simple. The GRASS Addon 'v.concave.hull' has a column definition that
does not work with the PostgreSQL backend:
Line 98:
grass.run_command('v.db.addtable', map = out_lines,
                    col = 'cat integer,length double', quiet = True)
That gives an error, whereas the simple replacement of `length double`
with `length double precision` makes the script run:
                       col = 'cat integer,length double precision', quiet =
True)
This should run at least with the sql-based backends since based on MySQL
and SQLite documentation the `double precision` is the full type name
anyway, but I do not know about DBF. But from what I've understood, the
use of DBF is not recommended any more anyway.
I could easily fix this myself, but I do not have write access to sources.
Harri
Ticket URL: <https://trac.osgeo.org/grass/ticket/3444&gt;
PostgreSQL
Resolution: | Keywords: v.concave.hull, PostgreSQL
Comment (by mlennert):
Fixed in r71741. Please reinstall the extension and test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3444#comment:1&gt;
PostgreSQL
Comment (by harrik):
Works now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3444#comment:2&gt;
PostgreSQL
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.concave.hull, PostgreSQL
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3444#comment:3&gt;
