[GRASS-dev] [GRASS GIS] #3453: i.segment.stats add-on : Empty output csv when flags ‘s’ is activated
Reporter: tgrippa | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: i.segment.stats | CPU: Unspecified
Platform: Unspecified |
Hi, I notice a bug in i.segment.stats. When using the ‘s’ flag, the output
csv is empty (in fact, the header is written, but not the rest of the
file).
I check the code I think the problem comes from L222-225 which are:
if area_measures:
  output_dict[values[0]] = output_dict[values[0]]+ [values for x in
stat_indices]
else:
  output_dict[values[0]] = [values for x in stat_indices]
and shoud be :
stat_indices]
I make the change on my local version of the add-on and it seems working
as expected.
Also, I noticed the L220 and L221 are duplicates.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3453&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: i.segment.stats
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"71822" 71822]:
#!CommitTicketReference repository="" revision="71822"
i.segment.stats: fix #3453 and object error output
Ticket URL: <https://trac.osgeo.org/grass/ticket/3453#comment:1&gt;
Comment (by mlennert):
Thanks for the report and fix. The issue also put the light on another
bug in the object error message output. Both should be fixed in r71822.
Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3453#comment:2&gt;
