GDAL
November 27, 2017, 10:40am
1
#3455: Grass 7.2.1 returns "Extension(...)not found" when installing addon
Reporter: bcbernardo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
In GRASS GIS 7.2.1 (from the QGIS 2.18 suite), running on Windows 7 32
bits SP1, installing any addon with g.extension returns:
Downloading precompiled GRASS Addons <extension.name>...
"ERROR: Extension <extension.name> not found"
Running the module with verbose flag on adds the following line to result:
"Downloading source code for <extension.name> from
<http://wingrass.fsv.cvut.cz/grass72/x86/addons/grass-7.2.1/extension.name.zip> ;
which is identified as 'remote_zip' type of source..."
I have been trying to perform these installations for a few days, with no
results, in more than one computer at my workplace. Re-installing QGIS
suite does not appear to make any difference. The company's policy on
downloading and opening executable files will not allow me to install a
GRASS GIS stand-alone. I do can download the zipfile manually from the
wingrass http index, though, which makes me think it is not a matter of
server availability (as reported
[https://gis.stackexchange.com/questions/262210/grass-gis-addon-extension-
not-found-could-the-problem-be-with-the-grass-addon elsewhere]) or
internet access restrictions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
November 27, 2017, 10:48am
2
Component: Default | Version: 7.2.1
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Changes (by hellik):
* platform: Unspecified => MSWindows 7
* version: unspecified => 7.2.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:1> ;
GDAL
November 27, 2017, 10:54am
3
Comment (by martinl):
Replying to [ticket:3455 bcbernardo]:
it's not clear how do you run the command, from GRASS Plugin Shell? Anyway
there is no 'extension.name' Addons, see (1)
(1) https://grass.osgeo.org/grass72/manuals/addons/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:2> ;
GDAL
April 9, 2019, 1:55am
4
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.4
Resolution: worksforme | Keywords:
Changes (by annakrat):
* status: new => closed
* resolution: => worksforme
Comment:
Reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:4> ;
GDAL
July 23, 2019, 10:25am
5
Type: defect | Status: reopened
Component: Addons | Version: 7.4.0
Changes (by vinhussey):
* status: closed => reopened
* cc: vinhussey (added)
* component: Default => Addons
* platform: MSWindows 7 => MSWindows
* version: 7.2.1 => 7.4.0
* resolution: worksforme =>
Comment:
The windows repository seems to be hardcoded to
http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/ (in grass
7.4 at least).
The files are actually located at
http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.svn/
C:\>g.extension
url="http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.svn/" ;
--verbose extension=v.tin.to.rast
Downloading precompiled GRASS Addons <v.tin.to.rast>...
Downloading source code for <v.tin.to.rast> from
<http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.4/v.tin.to.rast.zip> ;
ERROR: Extension <v.tin.to.rast> not found
As shown above, the url parameter does not appear to work (unless I am not
using it correctly).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:5> ;
GDAL
July 23, 2019, 10:55am
6
Comment (by vinhussey):
Copy scripts/g.extension.py to another location. Change as below. Run from
File > Launch Script. It now works.
base_url = "http://wingrass.fsv.cvut.cz/" ; \
"grass%(major)s%(minor)s/%(platform)s/addons/" \
"grass-%(major)s.%(minor)s.%(patch)s" % \
{'platform': platform,
'major': version[0], 'minor': version[1],
#'patch': version[2]}
'patch': 'svn'}
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:6> ;
GDAL
July 27, 2019, 6:51pm
7
Comment (by hellik):
Replying to [comment:5 vinhussey]:
7.4 at least).
> C:\>g.extension
not using it correctly).
the subject of the trac ticket is about **Grass 7.2.1v.** in windows.
winGRASS versions:
* GRASS GIS 7.4.4 (old stable)
* GRASS GIS 7.6.1 (new stable)
which winGRASS version are you refering to while reopening the ticket?
>/x86_64/addons/grass-7.4.4/ (in grass 7.4 at least).
precompiled addon python scripts may work between different winGRASS
releases; though it's very unlikely that C addons are working due to
different GRASS library version.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:7> ;
GDAL
July 27, 2019, 9:09pm
8
Replying to [comment:6 vinhussey]:
from File > Launch Script. It now works.
> 'patch': 'svn'}
see
https://lists.osgeo.org/pipermail/grass-dev/2019-July/092972.html
for a related dev discussion.
user input/point of view/ideas very appreciated for this discussion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:8> ;
GDAL
July 29, 2019, 9:50pm
9
Comment (by neteler):
I have created two pull requests:
* master: https://github.com/OSGeo/grass/pull/68
* relbranch76: https://github.com/OSGeo/grass/pull/69
If that works, then also relbranch74 etc. need related updates.
Please test (the pull request contains hints on testing).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:9> ;
GDAL
July 30, 2019, 9:35am
10
Is the server at http://wingrass.fsv.cvut.cz/ independent of the grass
project? If so there seems to be a risk of this re-occurring, so maybe a
more informative error message would be useful?
The simplest solution to my mind would be to agree a structure with the
maintainer of that server, so that the g.extension.py script is not
broken.
If that is not possible, could we ask the maintainer to provide a sitemap
that could be easily checked?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:10> ;
GDAL
December 17, 2020, 8:22am
11
Comment (by sbl):
Is this still an issue with more recent versions?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3455#comment:11> ;
