#3456: Trunk fails to compile on Xenial
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.4.0
Component: Compiling | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
Ubuntu Xenial ships with GDAL 1.11.3, released 2015/09/16. It seems that
trunk (most likely 7.4 too) needs a more recent GDAL version, still it
fails to detect it during configuration phase.
Either compatibility with GDAL 1.11 must be restored (v.out.ogr) or
configure should fail with an error of incompatible GDAL version.
gcc -g -O2 -I/home/marisn/soft/grass_trunk/dist.x86_64-pc-linux-
gnu/include -I/home/marisn/soft/grass_trunk/dist.x86_64-pc-linux-
gnu/include -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\"
-I/usr/include/gdal -I/home/marisn/soft/grass_trunk/dist.x86_64-pc-linux-
gnu/include -DRELDIR=\"vector/v.out.ogr\" -o OBJ.x86_64-pc-linux-
gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:473:49: error: ‘Ogr_driver’ undeclared (first use in this function)
G_debug(2, "driver %d : %s", i, OGR_Dr_GetName(Ogr_driver));
Resolution: | Keywords:
Comment (by mmetz):
Replying to [ticket:3456 marisn]:
Compatibility of v.out.ogr with GDAL 1.11 has been restored in trunk
r71854. Relbr74 is not affected.
