[GRASS-dev] [GRASS GIS] #3457: v.what test broken
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Keywords: v.what, tests | CPU: Unspecified
Platform: Unspecified |
v.what test was broken in r70700:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2017-03-01-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.what/test_vwhat_ncspm/index.html
Looking at the test results, v.what seems to actually give wrong results.
Note that developers are expected to at least run the existing tests
(ideally write new test) before submitting such changes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3457&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.what, tests
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"71859" 71859]:
#!CommitTicketReference repository="" revision="71859"
v.what: reset lists for each input map (fix #3457)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3457#comment:1&gt;
Comment (by mmetz):
In [changeset:"71860" 71860]:
#!CommitTicketReference repository="" revision="71860"
v.what: reset lists for each input map (fix #3457, backport trunk r71859)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3457#comment:2&gt;
Comment (by mmetz):
Replying to [ticket:3457 annakrat]:
results.
Fixed in r71859,60 (trunk, relbr74).
+1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3457#comment:3&gt;
