[GRASS-dev] [GRASS GIS] #3458: A vector consistently crashes digitizer
Reporter: harrik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 7.2.0
Keywords: vector, digitization | CPU: Unspecified
Platform: Linux |
The attached vector consistently crashes the digitizer. It was originally
imported form dxf via `v.in.ogr`, and was impossible to open in the
digitizer. I then exported it with `v.out.ascii` (see the attached file)
and tried opening it in a freshly created location, but even here, the
digitizer crashes with this vector map. It may be possible to open it, but
as soon as one zooms out so much that these lines should become visible,
the digitizer crashes with this error message:
     G_malloc: unable to allocate 18446744073709551608 bytes of memory at
lib/vector/vedit/render.c:312
I do wonder if this has something to do with the amount of decimal digits
in the file? Could it be that there's some kind of an overflow because of
this? The dxf was originally exported from AutoCAD, and the lines with
several digits in the coordinates are (my guess) approximations of curves
perhaps created by `ogr`.
Other vector operations seem to work fine, as far as I've tested.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3458&gt;
Resolution: | Keywords: vector, digitization
       CPU: Unspecified | Platform: Linux
Changes (by harrik):
* Attachment "test.grascii" added.
  Priority: normal | Milestone: 7.6.2
Changes (by martinl):
* milestone: 7.2.4 => 7.6.2
Comment:
Still relevant.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3458#comment:2&gt;
