[GRASS-dev] [GRASS GIS] #3461: STVDS and libgis error on OS X
Reporter: mankoff | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: LibGIS | Version: 7.2.2
Keywords: temporal, stvds | CPU: OSX/Intel
Platform: MacOSX |
I'm able to create STRDS on OS X, but STVDS aren't working. Following the
example here:
https://grasswiki.osgeo.org/wiki/Temporal_data_processing/seasonal_aggregation
the `t.register` command fails, with the following error:
> t.register type=vector input=points file=seasonal_points.txt
Gathering map information...
WARNING:root:Needed to restart the libgis server, caller: Server check
thread
ERROR: Exception raised: [Errno 9] Bad file descriptor Message:
        read_vector_info
This occurs on OS X with GRASS 7.2 installed via Fink or MacPorts. It does
not happen on Linux, leading me to believe this is an OS X specific bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461&gt;
Resolution: | Keywords: temporal, stvds
       CPU: OSX/Intel | Platform: MacOSX
Comment (by neteler):
Could you try to run the test framework of GRASS GIS?
https://grass.osgeo.org/grass73/manuals/libpython/gunittest_running_tests.html
Maybe it helps to isolate the problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461#comment:1&gt;
Comment (by mankoff):
Unfortunately I do not think I can do this. I have the GRASS source source
code from subversion on a Linux VM and I can compile and build there. I do
this for testing and because I hope to start contributing patches, not
just bug reports. But I do not know how to set up a test environment on OS
X, because the GRASS source does not properly build on OS X AFAIK. I am
aware of the patches and etc. that MacPorts/Fink/HomeBrew use to get it to
install, but I'm not familiar enough with those environments to step into
them and run the test commands you link to above.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461#comment:2&gt;
I apologize - it appears I can run these tests. They do not require
*compiling* the source.
I have some output, but don't know what to do with it.
From the terminal, I have:
> $GRASS_PYTHON -m grass.gunittest.main --location nc_spm_08_grass7
--location-type nc
test_dbcolumns from ./db/db.columns failed (1 test failed)
test_dbcopy from ./db/db.copy failed (4 tests failed)
test_dbdescribe from ./db/db.describe failed (2 tests failed)
toolboxes from ./gui/wxpython/core failed
gis_lib_str_color from ./lib/gis failed (14 tests failed)
test_assertions from ./lib/python/gunittest failed (4 tests failed)
test_assertions_vect from ./lib/python/gunittest failed (6 tests failed)
test_doctests from ./lib/python/pygrass failed (1 test failed)
test_doctests from ./lib/python/pygrass/gis failed (1 test failed)
test_history from ./lib/python/pygrass/raster failed (1 test failed)
test_doctests from ./lib/python/pygrass/rpc failed
test_doctests from ./lib/python/pygrass/vector failed
test_geometry from ./lib/python/pygrass/vector failed
test_geometry_attrs from ./lib/python/pygrass/vector failed
test_vector from ./lib/python/pygrass/vector failed
test_vector3d from ./lib/python/pygrass/vector failed
test_utils from ./lib/python/script failed (12 tests failed)
test_doctests from ./lib/python/temporal failed (11 tests failed)
etc...
I'm getting a lot of dialogs popping up alerting me that `Python quit
unexpectedly`. And I have the HTML test results in
`/testreport/testfiles.html`.
Where should I dig deeper?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461#comment:3&gt;
      Type: defect | Status: closed
  Priority: normal | Milestone: 7.2.4
Resolution: wontfix | Keywords: temporal, stvds
Changes (by mankoff):
* status: new => closed
* resolution: => wontfix
Comment:
Opting to close because I'm the only person who seemed affected by this
issue and I'm not using OS X any longer.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461#comment:5&gt;
