#3462: Allow setting environment variables in grass startup script
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.2.2
Keywords: | CPU: Unspecified
Platform: MacOSX |
In the grass72 startup script, in the function `def bash_startup(location,
location_name, grass_env_file):`
These lines exist:
for line in readfile(env_file).splitlines():
if not line.startswith('export'):
f.write(line + '\n')
If I comment out the 2nd line (and fix the indentation for the 3rd line
because this is Python), then I can add `export DYLD_LIBRARY_PATH=...` in
either `~/.grass.bashrc` or `~/.grass7/bashrc` and this fixes various
GRASS issues on OS X relating to the temporal framework.
Why does the startup script ignores `export` statements from the GRASS
config file? Is there a problem if I change this behavior?
In more detail, this is not an issue with Fink installations, but is with
MacPorts. Fink installs an OS X Application: GRASS.app. Deep in the app I
found a Makefile that seems to tell GRASS.app to respect
`GRASS_LD_LIBRARY_PATH`. The Macports version does not install an app, and
does not respect the `GRASS_LD_LIBRARY_PATH` variable. For some reason,
shell-level `LD_LIBRARY_PATH` and `DYLD_LIBRARY_PATH`'s are also not
respected (perhaps due to SIP?).
Environmental variables are loaded by load_env()
source:grass/trunk/lib/init/grass.py?rev=65585#L1710 from default config
file source:grass/trunk/lib/init/grass.py?rev=65585#L1220. In my case on
Linux (using Bash), it's `~/.grass7/bashrc`. Eg.
# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
# this works for subprocesses but won't affect the current process
path_prepend(gpath("lib"), ld_library_path_var)
I'm not clear how the comment in `grass.py` pointing to this ticket helps.
Certain critical environment variables that are **required** for GRASS to
work correctly cannot be set in either `~/.grass.bashrc` or
`~/.grass7/bashrc`, as long as the line ignoring `export` statements
remains. Why can't I `export` variables from these scripts?
Replying to [comment:8 mankoff]:
helps. Certain critical environment variables that are **required** for
GRASS to work correctly cannot be set in either `~/.grass.bashrc` or
As I mentioned earlier, the environment variables should be loaded by
`load_env()`. I tested your config file and it's working on my Linux
machine. So probably something related to MAC? Try to put more debug
message around `load_env()`.
Yes this is something MAC related. The Fink installation of GRASS gets
around this by modifying the program to look for a `GRASS_LIBRARY_PATH`
which lets me set the `DYLD_LIBRARY_PATH`. I'm using MacPorts and this
modification has not been made.
I get that as mentioned earlier, environment variables should be loaded by
`load_env()`. But nobody has offered an explanation for why `export`
statements are ignored here. GRASS is, generally, a power user tool and
lets the users do what they want. Why is it acting in such a protective
manner here?
Results from running GRASS with `GRASS_DEBUG=ON` are:
$ GRASS_DEBUG=ON grass72 -c EPSG:3413 ./Gtmp
DEBUG: GRASS_DEBUG environmental variable is set. It is meant to be an
internal variable for debugging only this script.
Use 'g.gisenv set="DEBUG=[0-5]"' to turn GRASS GIS debug mode on if you
wish to do so.
DEBUG: Environmental variable set BAR=42
DYLD_LIBRARY_PATH=/opt/local/share/grass-7.2.2/lib
DEBUG: Tmp directory
'/var/folders/7y/lbz1bs057398tql00m7fz0hr0000gn/T/grass7-kdm-10348'
created for user 'kdm'
Cleaning up temporary files...
access: No such file or directory
ERROR: LOCATION </Users/kdm/Gtmp> not available
Creating new GRASS GIS location/mapset...
DEBUG: Mapset </Users/kdm/Gtmp/PERMANENT> locked using
'/Users/kdm/Gtmp/PERMANENT/.gislock'
Welcome to GRASS GIS 7.2.2
GRASS GIS homepage: http://grass.osgeo.org
This version running through: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
Start the GUI with: g.gui wxpython
When ready to quit enter: exit
DEBUG: GRASS GUI should be <text>
.grass.bashrc
.grass7/bashrc
GRASS 7.2.2 (Gtmp):~ > env | grep BAR
BAR=42
GRASS 7.2.2 (Gtmp):~ > env | grep DY
by `load_env()`. But nobody has offered an explanation for why `export`
Well, then it's up to you to help us discovering where the problem is.
Nobody else was able till now to reproduce this bug. Than it's hard to
guess.
> generally, a power user tool and lets the users do what they want. Why
is it acting in such a protective manner here?
Instead of hacking around it would be nice to find out why `load_env()` is
not working in your case.
wish to do so.
For some reason, all of this "security" can easily be bypassed if the
GRASS startup script does not explicitly block `export` statements as in
the attached patch.
To try to clarify/summarize the above comments: OS X has a security
feature that makes `load_env()` not work properly, and therefore the
temporal framework is not available to OS X users. There is a simple work-
around: Remove one line in the startup script. Patch is attached.
There may be other ways to fix this bug, but I have not yet discovered
them, and the proposed fix is simple and has no downsides that I can see
or that anyone has mentioned in the comments.
I have asked but not received an explanation for why this line exists in
the startup script. The offending line blocks users from `export`'ing
environment variables in `~/.grass7/bashrc`. This decision confuses me -
GRASS is a power-user tool, and anyone setting environment variables there
presumably knows what they are doing.
Replying to [comment:15 mankoff]:
sorry, but you got an explanation! Please read carefully the comments.
There is a special procedure for loading environmental variables
(``load_env()``). That's reason why this line exists in the code.
Anyway I will prepare patch for security issue reported in MacOS. It will
be still workaround anyway.
