GDAL
January 17, 2018, 8:00am
21
#3462: Allow setting environment variables in grass startup script
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.3
Component: Startup | Version: 7.2.2
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by martinl):
Done in r72095, please try out fresh trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:18> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
January 17, 2018, 8:01am
22
Reporter: mankoff | Owner: martinl
Type: defect | Status: assigned
Changes (by martinl):
* status: new => assigned
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:19> ;
GDAL
February 27, 2018, 9:15pm
23
Does the fix work for you?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:20> ;
GDAL
February 27, 2018, 9:26pm
24
Comment (by mankoff):
Thank you for making the change! I'm sorry I did not thank you and
test/confirm the change previously. However - I cannot test it. I compile
GRASS dev versions on a Linux machine, but because OS X is only partially
supported, I have never gotten a full build/test environment working on OS
X. I need to wait until one of the package managers provides a version
with your updates. I recently upgraded to 7.4.0 but had to downgrade to
7.2.2 because 7.4.0 does not work with QGIS. I *think* you can close this
ticket (again, based on visual inspection of the change).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:21> ;
GDAL
February 27, 2018, 10:17pm
25
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:21 mankoff]:
X.
Did you try this?
https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
> I need to wait until one of the package managers provides a version with
your updates. I recently upgraded to 7.4.0 but had to downgrade to 7.2.2
It meanwhile does:
https://github.com/qgis/QGIS/pull/6394
* present in QGIS 3.0.0: https://github.com/qgis/QGIS/blob/release-
3_0/cmake/FindGRASS.cmake
* present in QGIS 2.18.17: https://github.com/qgis/QGIS/blob/release-
2_18/cmake/FindGRASS.cmake
> I *think* you can close this ticket (again, based on visual inspection
of the change).
Backport?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:22> ;
GDAL
February 27, 2018, 10:18pm
26
Type: defect | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
Reopen for backport (to 7.4 at least?)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:23> ;
GDAL
February 28, 2018, 7:31am
27
Did you try this?
I wrote the instructions there for 7.2. At the time the "How to install
GRASS GIS 7.1 SVN Head" section didn't work on 7.2 head. And I'm no longer
using Homebrew but MacPorts - so no I cannot easily test non-packaged
versions on OS X :(.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:24> ;
GDAL
September 3, 2018, 9:23pm
28
Priority: major | Milestone: 7.6.0
Resolution: fixed | Keywords: init grass.py env D_LIBRARY_PATH
CPU: | bashrc
Changes (by wenzeslaus):
* keywords: => init grass.py env D_LIBRARY_PATH bashrc
* status: reopened => closed
* milestone: 7.2.4 => 7.6.0
Comment:
This was already fixed and reopened for backport in comment:23. This may
not be a change which is appropriate to backport. At this point, it will
just be in 7.6. Changing milestone. Closing as fixed.
For the record, GRASS GIS itself doesn't use `GRASS_LD_LIBRARY_PATH` at
this point.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:27> ;
