#3464: winGRASS compilation: Error:
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:144: Syntax error at
'va_list'
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-releasebranch74
Keywords: | CPU: All
Platform: MSWindows 8 |
looking at the
[https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r71899-24/package.log
winGRASS compilation logs], there are quite a lot error messages like:
Status: Preprocessing c:\users\landa\appdata\local\temp\tmpt1iov5.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-I/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1"
c:/users/landa/appdata/local/temp/tmpt1iov5.h
Status: Parsing c:\users\landa\appdata\local\temp\tmpt1iov5.h
Status: Processing description list.
Warning: Member "from" of Struct "DateTime" has been renamed to "_from"
because it has the same name as a Python keyword.
Status: Writing to OBJ.x86_64-w64-mingw32/date.py.
Status: Wrapping complete.
GISRC=/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/demolocation/.grassrc75
GISBASE=C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32
PATH="/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/scripts:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/lib:/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/lib:/usr/bin:/mingw64/bin/:/c/OSGeo4W64/bin:/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/lib:/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w"
LC_ALL=C LANG=C LANGUAGE=C ./ctypesgen.py --cpp "gcc -E
-D__GLIBC_HAVE_LONG_LONG" -lgrass_gis.7.5.svn -lintl-8
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/colors.h
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/colors.h
-o OBJ.x86_64-w64-mingw32/gis.py
Status: Preprocessing c:\users\landa\appdata\local\temp\tmpfj4azr.h
c:/users/landa/appdata/local/temp/tmpfj4azr.h
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:275:0,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\include\grass\gis.h:24,
c:/users/landa/appdata/local/temp/tmpfj4azr.h:1:
C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error
VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: ^
Status: Parsing c:\users\landa\appdata\local\temp\tmpfj4azr.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:144: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:150: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:156: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:161: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:170: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:176: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:188: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:381: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:382: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:383: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:393: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:394: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:395: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:529: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:538: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:543: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:545: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:567: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:577: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:581: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:585: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:592: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:594: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:598: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:602: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:729: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:730: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:731: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:757: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:758: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:787: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:789: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:799: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:804: Syntax
error at 'argp'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:811: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:813: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:821: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:835: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:27:
Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:36:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:37:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:39:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:42:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:45:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:57:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:58:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:59:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:61:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:64:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:65:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:68:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:69:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:72:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:73:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:76:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:77:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:79:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:81:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:83:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:85:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:88:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:89:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:107:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:108:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:110:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:116:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:124:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:126:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:128:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:130:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:145:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:146:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:148:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:150:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:153:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:154:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:157:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:158:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:161:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:162:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:165:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:167:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:169:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:170:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:63:
Syntax error at '{'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:64:
Syntax error at ':'
Error:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:157:
Error: Typedef "__time64_t" depends on an unknown typedef "__int64".
Typedef "__time64_t" will not be output
Warning: Member "def" of Struct "Option" has been renamed to "_def"
Error: Struct "_stat64" depends on an unknown typedef "__int64". Struct
"_stat64" will not be output
Warning: Could not parse macro "#define serialize_int32_le(buf,x) do { (
buf ) [ i0 ] = ( ( x ) >> i0 ) & i255 ; ( buf ) [ i1 ] = ( ( x ) >> i8 ) &
i255 ; ( buf ) [ i2 ] = ( ( x ) >> i16 ) & i255 ; ( buf ) [ i3 ] = ( ( x )
>> i24 ) & i255 ; } while ( i0 )"
Warning: Could not parse macro "#define serialize_int32_be(buf,x) do { (
buf ) [ i0 ] = ( ( x ) >> i24 ) & i255 ; ( buf ) [ i1 ] = ( ( x ) >> i16 )
& i255 ; ( buf ) [ i2 ] = ( ( x ) >> i8 ) & i255 ; ( buf ) [ i3 ] = ( ( x
) >> i0 ) & i255 ; } while ( i0 )"
Status: Writing to OBJ.x86_64-w64-mingw32/gis.py.
-D__GLIBC_HAVE_LONG_LONG" -lgrass_raster.7.5.svn
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/raster.h
/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/raster.h
-o OBJ.x86_64-w64-mingw32/raster.py
Status: Preprocessing c:\users\landa\appdata\local\temp\tmpwjeiup.h
c:/users/landa/appdata/local/temp/tmpwjeiup.h
Ticket URL: <https://trac.osgeo.org/grass/ticket/3464>
