[GRASS-dev] [GRASS GIS] #3465: add zstd as dependency to setup.hint in OSGeo4W-winGRASS-trunk 32/64bit
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
see
https://lists.osgeo.org/pipermail/grass-dev/2017-December/086776.html
GRASS GIS has the new feature to compress raster data with the zstd
algorithm.
to enable it also for winGRASS trunk, zstd should be added to setup.hint
in OSGeo4W.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3465&gt;
      Type: defect | Status: closed
Component: Packaging | Version: svn-trunk
Resolution: fixed | Keywords:
       CPU: All | Platform: MSWindows 8
Changes (by hellik):
* status: new => closed
* component: Default => Packaging
* platform: Unspecified => MSWindows 8
* version: unspecified => svn-trunk
* resolution: => fixed
* cpu: Unspecified => All
Comment:
done by r71912, closing ticket
Ticket URL: <https://trac.osgeo.org/grass/ticket/3465#comment:1&gt;
