[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
Reporter: sbl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Packaging | Version: unspecified
Keywords: i.atcorr | CPU: Unspecified
Platform: Unspecified |
It seems that Sentinel-2 functions in i.atcorr are effectively broken in
some release packages and on some systems.
The following installations have been reported to only return NULL values
in output:
* Ubuntu 16.04 with GRASS 7.4.0RC1 from UbuntuGIS-experimental
* UBUNTU 14.04 with GRASS 7.4.0RC1 self compiled with gcc 5.4.1 (and
older)
* UBUNTU 14.04 with GRASS 7.5 self compiled with gcc 4.8
* Windows 8.1 with GRASS 7.4.0RC1 and 7.5 daily from OSGeo4W
However, the following systems produce reasonable output:
* UBUNTU 16.04.3 LTS with GRASS 7.4 and 7.5 self compiled with gcc 5.4.0
20160609 Ubuntu 5.4.0-6ubuntu1~16.04.5
* Fedora 27 with GRASS 7.4.0RC1 and 7.5 self compiled with gcc 7.2.1
20170915
Test case below, test data attached to the ticket.
r.in.gdal input=dem.tif output=dem –o -–v --o
r.in.gdal
input=S2A_OPER_PRD_MSIL1C_PDMC_20160907T044118_R008_V20160905T104022_20160905T104245.B08.tif
output=B08 -o -–v --o
g.region -p raster=B08 align=B08
i.atcorr -r input=B08 elevation=dem range=0,10000 output=test_atcorr
rescale=0,10000 parameters=p6s.txt -–v --o
relevant compiler flags are:
-g -Wall -Wextra -Wpedantic -Wshadow -Wno-sign-compare -fno-common
-fexceptions -Werror=implicit-function-declaration -Wp,-D_FORTIFY_SOURCE=2
-O3 -fno-fast-math
-fno-fast-math might be important
Finally, running i.atcorr through valgrind (on Fedora) gives lots of the
following warnings, that according to MarkusM should be investigated:
==14080== Conditional jump or move depends on uninitialised value(s)
==14080== at 0x42B18D: os(float, float, float, float, float, float (&)
[51][49], Gauss&, Altitude const&, GeomCond const&) (computations.cpp:831)
==14080== by 0x42E9E3: atmref(float, float, float, float, float,
OpticalAtmosProperties&, Gauss&, GeomCond const&, AerosolModel const&,
Altitude const&) (computations.cpp:1408)
==14080== by 0x42FCBC: discom(GeomCond const&, AtmosModel const&,
AerosolModel const&, AerosolConcentration const&, Altitude const&, IWave
const&) (computations.cpp:1654)
==14080== by 0x40C032: init_6S(char*) (6s.cpp:100)
==14080== by 0x405A3C: main (main.cpp:618)
later on
==14080== at 0x42DED8: iso(float, float, float, float, float, float (&)
[3], Gauss&, Altitude const&) (computations.cpp:1262)
==14080== by 0x42F011: scatra(float, float, float, float, float,
OpticalAtmosProperties&, Gauss&, GeomCond const&, Altitude const&)
(computations.cpp:1578)
==14080== by 0x42FD08: discom(GeomCond const&, AtmosModel const&,
const&) (computations.cpp:1659)
==14080== by 0x406882: pre_compute_h(float) (6s.cpp:148)
==14080== by 0x406372: process_raster (main.cpp:369)
==14080== by 0x406372: main (main.cpp:632)
For ML discussion see:
https://lists.osgeo.org/pipermail/grass-user/2017-December/077545.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469&gt;
Resolution: | Keywords: i.atcorr
Changes (by sbl):
* Attachment "p6s.txt" added.
6s parameters (UNIX line endings)
Changes (by sbl):
* Attachment "dem.tif" added.
DEM
Changes (by sbl):
* Attachment
"S2A_OPER_PRD_MSIL1C_PDMC_20160907T044118_R008_V20160905T104022_20160905T104245.B08.tif"
added.
Sentinel-2 Band 8
Comment (by mlennert):
I'm on Debian testing with gcc (Debian 7.2.0-17) 7.2.1 20171205.
Using fresh trunk with the following compiler settings:
CFLAGS="-g -Wall -fopenmp -lgomp -Ofast -fno-fast-math
-march=core-avx-i -fno-common -fexceptions $PENTIUM64"
LDFLAGS="-Wl,--no-undefined -fopenmp -lgomp"
CXXFLAGS="-g -Ofast"
and applying the exact commands given in this ticket, I get as result:
r.info -r test_atcorr
min=NULL
max=NULL
Several questions:
* In the discussion in the mailing list, some examples were with i.atcorr
-r, others without. Do we agree that in this case it should be with -r as
the data contains reflectance information ?
* What is the exact meaning and impact of the range setting ?
* Stefan, any special reason why you import your data with '-o' ? Why not
create an EPSG 32633 location and import the data there ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:1&gt;
Comment (by mmetz):
Replying to [comment:1 mlennert]:
-Ofast is dangerous. I would regard any optimization larger than -O3 as
experimental. Some code only runs properly with max -O1.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:2&gt;
Comment (by sbl):
> Several questions:
i.atcorr -r, others without. Do we agree that in this case it should be
with -r as the data contains reflectance information ?
Yes, I would say so.
not create an EPSG 32633 location and import the data there ?
Laziness ;-): We usually treat 32633 and 25833 as identical (max
difference in Norway is reported to be ~40cm). So, I just did not want to
create a new location for testing with Sajids data...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:3&gt;
Replying to [comment:2 mmetz]:
I just recompiled with all compiler flags commented out. Same result, i.e.
all NULLs. Now I have to go into a meeting and cannot test further.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:4&gt;
Using
CFLAGS=-g -Wall -Wextra -Wpedantic -Wshadow -Wno-sign-compare -fno-common
-O3 -fno-fast-math
I again get
min=NULL
max=NULL
So not sure it's the compiler flags...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:5&gt;
Comment (by mmetz):
Replying to [comment:5 mlennert]:
> Using
common -fexceptions -Werror=implicit-function-declaration
-Wp,-D_FORTIFY_SOURCE=2 -O3 -fno-fast-math
Are you still using
i.atcorr is a C++ module
> I again get
> min=NULL
> max=NULL
I can confirm on Debian testing, all NULL...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:6&gt;
Replying to [comment:6 mmetz]:
> > Using
> Are you still using
No. I left all ldflags and cxxflags commented, and I don't think -Ofast is
default.
Good to know. So do CFLAGS have any impact ?
> > I again get
> > min=NULL
> > max=NULL
Good. This means that it is something systematic which we should be able
to find. Stefan, you tried different versions. Are there any older
versions which work for you ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:7&gt;
Comment (by mmetz):
Replying to [comment:7 mlennert]:
> [...] This means that it is something systematic which we should be able
It seems that the 6s code in i.atcorr is numerically unstable: some
internal variables can get very close to zero. If these close-to-zero
values are snapped to zero, nan and inf results can appear. This is why
the result can be all NULL, or not.
The symptom can be cured by using double precision floating point
variables throughout. Currently, i.atcorr uses single precision floating
point variables. When using double precision floating point variables,
Debian testing produces reasonable results. However, these results differ
from Fedora 27, also using double precision floating point variables
throughout. I would say that both results (Debian testing and Fedora 27)
are slightly wrong because of the numerical instability of the 6s code in
combination with the sentinel-2 parameters.
I suggest to review the parameters for sentinel-2 as used by i.atcorr.
I also suggest to review i.atcorr. The code has been translated from
Fortran to C++ and might need some manual adjustments.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:8&gt;
Comment (by sbl):
Replying to [comment:8 mmetz]:
Would you be able to provide a patch with those changes? I would not mind
slightly wrong results, just I am able to proceed. I can update the
computation once this is properly fixed...
I will happily test any fixes on various systems!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:9&gt;
Changes (by mmetz):
* Attachment "i_atcorr_double.patch" added.
patch to use double precision fp
Comment (by mmetz):
Replying to [comment:9 sbl]:
mind slightly wrong results, just I am able to proceed. I can update the
Patch i_atcorr_double.patch attached. i.atcorr is identical in 7.4 and
7.5, therefore the patch works with both versions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:10&gt;
Replying to [comment:10 mmetz]:
Thanks for investigating this !
I now get what looks like more reasonable results:
min=0.3878489
max=8513.962
compared to the original before correction:
r.info -r B08
min=83
max=7110
Interestingly, i.atcorr also runs much faster with the patch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:11&gt;
Comment (by sbl):
Yes, thanks so much Markus!
With the patch i.atcorr gives now also numbers on Ubuntu 14.04:
min = 0 max = 8514
So results are identical to Moritz`s.
I noticed that although "rescale" option was set to be 0-10000, maximum
output was 8514...\\
With e.g. Landsat paramters, i.atcorr scales to the full range provided in
rescale...
And yes, it is much faster for Sentinel-2 now...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:12&gt;
Comment (by mmetz):
Replying to [comment:12 sbl]:
> min = 0 max = 8514
With
I get
min=8.736016e-10
max=10000
on Fedora 27
and
min=8.708314e-10
max=10000
on Debian testing (Buster)
So there is some non-NULL output, but it differs between systems. Not so
nice.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:13&gt;
Comment (by sbl):
Replying to [comment:13 mmetz]:
nice.
Sorry, we should have reported the command we used. If I run exactly your
case:
I get the same output as you:
min=8.708314e-10
max=10000
So, it seems to be essential to use both range and rescale option if one
wants the data to be exactly in a given range of values...
Maybe something to clarify in the manual or set as a parser rule / warning
in the module?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:14&gt;
> min = 0 max = 8514
This depends on your input data and your range parameter:
r.info -r B08
min=83
max=7110
i.atcorr -r input=B08 elevation=dem range=83,7110 output=test_atcorr
rescale=0,10000 parameters=BROL/STEFAN/p6s.txt --v --o
min=8.732422e-10
max=10000
i.e. if you tell it to scale the input data range to 0,10000 it will do
so, but if you tell it that the input range is 1,10000 then it will scale
this range to 0,10000.
Markus, could it be that you are using the original larger input image
from the ML and not the smaller clip attached to this ticket ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:15&gt;
