#3475: r.mapcalc expression does not accept fully qualified map name as an output
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Raster | Version: svn-trunk
Keywords: r.mapcalc | CPU: Unspecified
Platform: Unspecified |
All raster and vector modules should accept fully qualified map name as an
output parameter and ignore @mapset part as long as mapset == current
mapset. This is implemented in Vect_open_new() and G_open_raster_new().
Still r.mapcalc is failing with an error:
mapcalc> sample@mapset=1
syntax error, unexpected '@', expecting '('
See extra discussion at bug #676
I'll try to fix r.grow code to strip @mapset part as a workaround as at
the moment it fails to overwrite an existing map when called from WXGUI.
Priority: minor | Milestone: 7.2.4
Resolution: | Keywords: r.mapcalc
Comment (by Nikos Alexandris):
Is there any activity on this? I have the following pending for a recently
published add-on:
{{{#!python
/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap.recreation
--overwrite land=land_suitability@examples potential=potential
Parse error
ERROR: parse error
File "/osgeo/grasstrunk/dist.x86_64-pc-linux-
gnu/scripts/r.estimap.recreation", line 4103, in <module>
sys.exit(main())
gnu/scripts/r.estimap.recreation", line 3631, in main
r.mapcalc(subset_land)
gnu/etc/python/grass/pygrass/modules/interface/module.py",
line 651, in __call__
return self.run()
line 772, in run
self.wait()
line 797, in wait
module=self.name, errors=stderr)
grass.exceptions.CalledModuleError: Module run r.mapcalc
r.mapcalc expression=tmp.5319.8.land_suitability@examples =
land_suitability@examples region=current ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
Removing temporary files
