[GRASS-dev] [GRASS GIS] #3478: g.extension does not work with bitbucket repo
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: Default | Version: svn-trunk
Keywords: g.extension | CPU: Unspecified
Platform: Linux |
Using G7:g.extension to install an addon from a bitbucket repo gives
error. Here is the command and error:
g.extension extension=t.rast.in.gpm
url=https://bitbucket.org/lrntct/t.rast.in.gpm
Fetching <http://t.rast.in.gpm> from
<https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip&gt; (be
patient)...
ERROR: Extension <http://t.rast.in.gpm> not found
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478&gt;
Resolution: | Keywords: g.extension
       CPU: Unspecified | Platform: Linux
Comment (by neteler):
Confirmed. Opening the URL, I get
Cannot resolve the cset
Seems that bitbucket has changed something which requires a change in
g.extension?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:1&gt;
  Priority: normal | Milestone: 7.8.0
Changes (by veroandreo):
* milestone: 7.4.5 => 7.8.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:6&gt;
Comment (by annakrat):
In [changeset:"74376" 74376]:
#!CommitTicketReference repository="" revision="74376"
g.extension: fix bitbucket download, assumes master branch, see #3478
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:7&gt;
Please test, probably should be backported. Note that it will download zip
always from master branch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:8&gt;
Comment (by veroandreo):
It seems to work as expected now, extension successfully installed.
Backport?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:9&gt;
In [changeset:"74412" 74412]:
#!CommitTicketReference repository="" revision="74412"
(merge from trunk, r74376)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.extension
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3478#comment:11&gt;
