[GRASS-dev] [GRASS GIS] #3480: m.cogo enhancement request: add declination support
Reporter: fgfletcher | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Default | Version: 7.0.1
Keywords: m.cogo | CPU: Unspecified
Platform: MacOSX |
m.cogo converts a sequence of (bearing,distance) pairs into cumulated
cartesian (x,y) coordinates beginning from a user provided starting x,y
position.
The bearing entry is in the form "N 52:17:04 W", widely used in survey
maps.
However, many surveys use magnetic bearings which are rotated from true
geographic North by an angle called the Declination - which itself depends
on the date and survey location.
Currently when using m.cogo with such data it is first necessary to
convert the magnetic bearing by adding(subtracting) the Declination as
known for the date and location of the survey.
This is tedious and error prone when a survey could consist of hundreds of
bearings, especially as adding a declination can "wrap around" a bearing
into a different quadrant, for example: a 15° declination wrapping from N
10 E to N 5 W.
It would be very helpful if one could provide a Declination argument to
m.cogo which would be added to each bearing. All that is needed in
processing is to add the Declination value to the Azimuth (from input
bearing) and handle the special cases of result <0 or >= 360.
Way above my skill level, but I'm hoping somebody might take an interest.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3480&gt;
  Priority: normal | Milestone: 7.8.0
Resolution: | Keywords: m.cogo
       CPU: Unspecified | Platform: MacOSX
Changes (by sbl):
* milestone: 7.2.4 => 7.8.0
Comment:
All enhancements should point to 7.8
Ticket URL: <https://trac.osgeo.org/grass/ticket/3480#comment:2&gt;
