#3486: v.in.ogr: default format in online manual
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.4.1
Component: Docs | Version: unspecified
Keywords: v.out.ogr | CPU: Unspecified
Platform: Unspecified |
the online manual for G74:v.out.ogr still shows 'Esri Shapefile' as
default format. Default format should be GPKG
source:grass/branches/releasebranch_7_4/vector/v.out.ogr/list.c#L99.
Any chance to update GDAL to version 2 on build server?
Resolution: | Keywords: v.out.ogr
Comment (by mmetz):
Replying to [ticket:3486 martinl]:
> Hi,
Earlier versions of GDAL also support GPKG. Is it possible that the build
server has a minimal GDAL installation built without SQLite3? The
GeoPackage driver needs SQLite3.
Comment (by neteler):
Replying to [comment:1 mmetz]:
build server has a minimal GDAL installation built without SQLite3? The
Yes, the grass.osgeo.org server is meanwhile a bit antique:
Comment (by martinl):
Comment (by mmetz):
Replying to [comment:3 martinl]:
> There is SQLite support included
> martinl@osgeo6:~$ ogrinfo --formats | grep GPKG
> martinl@osgeo6:~$ ogrinfo --formats | grep SQLite
> -> "SQLite" (read/write)
> It seems to me that GPKG driver has been introduced in GDAL 1.11.
Probably we should fix G74:v.out.ogr to reflect also this version.
The GPKG driver is only the default if it is available, therefore the
manual on the build server is correct.
Comment (by mlennert):
Replying to [comment:2 neteler]:
> neteler@osgeo6:~$ cat /etc/issue
> Debian GNU/Linux 8 \n \l
> neteler@osgeo6:~$ gdal-config --version
> 1.10.1
> neteler@osgeo6:~$ which gdal-config
> /usr/bin/gdal-config
> Anyone with more Debian experience than me: is there a better GDAL
binary package we could install? Or do I/MartinL have to compile GDAL from
scratch?
There are no gdal packages in jessie-backports, so I'm afraid that
compilation is necessary.
Jessie is old-stable. The current Debian stable release (stretch) has gdal
2.12.
Following stable releases would probably be enough to have relatively up
to date packages...
Replying to [comment:5 mlennert]:
gdal 2.12.
Inded, having an updated server would solve several issues.
to date packages...
Fully agreed. However, the osgeo6 machine hosts git, grass, ossim, svn,
and trac.
Hence an update is complex and needs to be done by OSGeo-SAC.
Priority: normal | Milestone: 7.4.2
Replying to [comment:6 neteler]:
gdal 2.12.
up to date packages...
and trac.
Well, we could compile GRASS GIS within a docker container on osgeo6. As
soon as I find the time I'll look into this.
#3486: v.in.ogr/v.out.ogr: default format in online manual
Replying to [comment:8 neteler]:
First attempt, compilation within docker manually triggered:
Priority: normal | Milestone: 7.4.5
Comment (by sylvain):
I was happy to see support for geopackage under grass but when I would
like to use it, it's only available for v.out.ogr !
Is there plan to add support for v.in.ogr and r.out.gdal (geopackage
support rasters).
Replying to [comment:14 Sylvain POULAIN]:
support rasters).
Comment (by mmetz):
> Hi,
v.in.ogr can already read GPKG (automatically recognized by OGR)
Comment (by Sylvain POULAIN):
Problem is about wxgui sorry for this misunderstanding !
With v.in.ogr, GPKG is not present in file listing but is present in
directory (I didn't notice that until today). Even with that, you could
not select gpkg from file with the GUI ("v.in.ogr -f | grep GPKG" is ok !)
With r.out.gdal, it's not present in the list but could be changed
manually. ("r.out.gdal -l | grep GPKG" is ok !
But Idea is : some promotes gpkg but it's not in the totally support in
Grass Gui (r.in.gdal is ok)
Comment (by mmetz):
Replying to [comment:19 Sylvain POULAIN]:
> But Idea is : some promotes gpkg but it's not totally support in Grass
I see. Changed in trunk r74122, the GUI knows now about GeoPackages.
I have a compile environment ready on the new grasslxd server, we may now
decide if to copy the manual pages over to grass.osgeo.org or migrate the
CMS to new grasslxd server and switch the IP.
