[GRASS-dev] [GRASS GIS] #3490: pygrass: improve error messages for table handling
Reporter: sbl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Python | Version: unspecified
Keywords: pygrass,vector,SQLite | CPU: All
Platform: All |
When I try to create a new vector map in pygrass where columns in the
attribute table (SQLite) contain "." (e.g. "landsatIm.5")
new.open() fails saying first that table exisits and then that it does not
exist:
   File
"/home/NINA.NO/stefan.blumentrath/.grass7/addons/scripts/i.pysptools.unmix",
line 329, in <module>
     sys.exit(main())
   File
line 272, in main
     new.open('w', tab_name=endmembers, tab_cols=cols)
   File
"/home/NINA.NO/stefan.blumentrath/grass-7.4.0svn/etc/python/grass/pygrass/vector/abstract.py",
line 381, in open
     self.n_lines = self.table.n_rows()
   File
"/home/NINA.NO/stefan.blumentrath/grass-7.4.0svn/etc/python/grass/pygrass/vector/table.py",
line 1053, in n_rows
     cur.execute(sql.SELECT.format(cols='Count(*)', tname=self.name))
sqlite3.OperationalError: no such table: test_end
However, after a bit of troubleshooting, I realized that the dots were
causing the issue.
Would be helpful if pygrass could check for "GRASS compliant" column names
and give more specific error messages. An alternative could be to support
quoted identifiers throughout the code, but that is probably a too big
effort (or something for GRASS 8?)...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3490&gt;
Resolution: | Keywords: pygrass,vector,SQLite
       CPU: All | Platform: All
Comment (by sbl):
See also: #3071 regarding effects of not quoting SQL identifiers...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3490#comment:1&gt;
  Priority: normal | Milestone: 7.6.2
Changes (by sbl):
* milestone: 7.2.4 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3490#comment:3&gt;
