[GRASS-dev] [GRASS GIS] #3491: i.group cannot read from other mapsets
Reporter: sbl | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Imagery | Version: unspecified
Keywords: i.group | CPU: All
Platform: All |
Using i.group on imagery groups in other mapsets unfortunately does not
work.
Seems to be a known limitation as I get the following error message:
ERROR: Group must exist in the current mapset
Would however be nice to be able to read groups from other mapsets, if
non-modifying operations with i.group (l,s,g-flag) would be allowed...
Tagging it as enhancement as behavior is deliberately as it is at the
moment...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491&gt;
Resolution: | Keywords: i.group
       CPU: All | Platform: All
Comment (by neteler):
The group management has been discussed long time back, see also #70 and
https://lists.osgeo.org/pipermail/grass-dev/2008-June/038371.html
However, things can certainly be discussed and their technical feasibility
be revisited again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491#comment:1&gt;
  Priority: normal | Milestone: 7.8.0
Changes (by sbl):
* milestone: 7.2.4 => 7.8.0
Comment:
Enhancement tickets should point to 7.8.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491#comment:3&gt;
Comment (by marisn):
There have been some changes in group handling. IMHO this issue has been
fixed in r73633 and r74107
Please test with trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491#comment:4&gt;
Comment (by sbl):
Partly fixed I would say:
grass77 ./nc_spm_full_v2alpha/user1/ --exec i.group group=mygroup
subgroup=subgroup input=aspect,basin,boundary --o
Starting GRASS GIS...
Cleaning up temporary files...
Executing <i.group group=mygroup subgroup=subgroup
input=aspect,basin,boundary --o> ...
Adding raster map <aspect@PERMANENT> to group
Adding raster map <basin@PERMANENT> to group
Adding raster map <boundary@PERMANENT> to group
Adding raster map <aspect@PERMANENT> to subgroup
Adding raster map <basin@PERMANENT> to subgroup
Adding raster map <boundary@PERMANENT> to subgroup
Execution of <i.group group=mygroup subgroup=subgroup
input=aspect,basin,boundary --o> finished.
grass77 ./nc_spm_full_v2alpha/stefan --exec i.group group=mygroup@user1 -l
Executing <i.group group=mygroup@user1 -l> ...
group <mygroup> references the following raster maps
<aspect@PERMANENT> <basin@PERMANENT> <boundary@PERMANENT>
Execution of <i.group group=mygroup@user1 -l> finished.
Cleaning up default sqlite database ...
However, groups from other mapsets are still not fullly useable e.g. in
i.cluster.
grass77 ./nc_spm_full_v2alpha/stefan/ --exec i.cluster group=mygroup@user1
subgroup=subgroup signaturefile=sign classes=3
Executing <i.cluster group=mygroup@user1 subgroup=subgroup
signaturefile=sign classes=3> ...
WARNING: Subgroup <subgroup> doesn't have any raster maps
ERROR: Subgroup must have at least 2 raster maps
Execution of <i.cluster group=mygroup@user1 subgroup=subgroup
signaturefile=sign classes=3> finished.
In addition, i.cluster seems to try to write to the imagery group
directory in the other mapset (the signature file), so further adjustments
downstreams seem to be required...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491#comment:5&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: i.group
Changes (by marisn):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 sbl]:
No, this issue is completely fixed as it was about i.group.
i.cluster.
This is a different issue. Groups are designed to be useable only in the
current mapset. I changed i.group behaviour as I have new i. modules just
reading from and not writing to groups and thus being fine with current
changes. Other i. modules still follow the old design principles.
I am closing this issue as fixed. A discussion on group/subgroup behaviour
in context of i. modules writing their files into group should be held and
accordingly new issues should be opened per each module not matching
expected behaviour.
See also: #3525 and https://marc.info/?l=grass-dev&m=152474676813985&w=2
and https://marc.info/?l=grass-dev&m=152481635118286&w=2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3491#comment:6&gt;
