[GRASS-dev] [GRASS GIS] #3496: v.in.pdal: does not compile with PDAL 1.6.0
Reporter: felixg | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: unspecified
Keywords: v.in.pdal, PDAL, lidar | CPU: Unspecified
Platform: Unspecified |
As the PDAL API changed in a few places, the code of v.in.pdal fails to
compile and needs to be adjusted.
The attached patch file changes the following in `main.cpp` of v.in.pdal:
- the includes as PDAL relocated some header files
- use of the enum pdal::Dimension::Id
- a method call to pdal::SpatialReference::getWKT(), it does not have any
formal parameters anymore in PDAL
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496&gt;
Resolution: | Keywords: v.in.pdal, PDAL, lidar
Changes (by felixg):
* Attachment "fix-for-pdal-vector-import.patch" added.
Comment (by wenzeslaus):
In [changeset:"72246" 72246]:
#!CommitTicketReference repository="" revision="72246"
v.in.pdal: change API calls to PDAL 1.6.0, see #3496 and #2732 (author:
felixg)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:1&gt;
Thank you. I committed the change in r72246. Tested with 1.5.0 and 1.6.0
(compiled) and trunk using the two tests in testsuite directory:
export LD_LIBRARY_PATH="/home/.../install/lib:$LD_LIBRARY_PATH"
cd vector/v.in.pdal/testsuite
../../../bin.x86_64-pc-linux-gnu/grass75
~/grassdata/nc_basic_spm_grass7/user1/ \
     --exec python basic_test.py
     --exec python filter_test.py
This can be closed after backport to 7.4 (and maybe 7.2).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:2&gt;
Comment (by neteler):
In [changeset:"72253" 72253]:
#!CommitTicketReference repository="" revision="72253"
felixg, trunk r72246) + GPL header added in r72245
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:3&gt;
  Priority: normal | Milestone: 7.4.1
Component: Vector | Version: svn-releasebranch74
Changes (by neteler):
* version: unspecified => svn-releasebranch74
* milestone: => 7.4.1
Comment:
Replying to [comment:2 wenzeslaus]:
Backported to 7.4 in r72253, closing.
@felixg: thanks for the patch!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.in.pdal, PDAL, lidar
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:5&gt;
In [changeset:"72363" 72363]:
#!CommitTicketReference repository="" revision="72363"
v.in.pdal: change API calls to PDAL 1.6.0, see #3496, #3243, #3101, #2732
(author: felixg, backport of trunk r72246) + GPL header added in r72245
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496#comment:6&gt;
