#3498: Can't open NetCDF file
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: Default | Version: 7.4.0
Keywords: | CPU: Unspecified
Platform: MacOSX |
In GRASS 7.2.2 I can read a netCDF file:
r.in.gdal -o input=netCDF:${ROOT}/MOD6_2000.nc:gld band=1 output=tmp --o
WARNING: Over-riding projection check
Proceeding with import of 366 raster bands...
Importing raster map <tmp>...
In GRASS 7.4.0, I cannot:
ERROR 10: Pointer 'hSRS' is NULL in 'OSRIsProjected'.
ERROR 10: Pointer 'hSRS' is NULL in 'OSRIsGeographic'.
Input contains an invalid SRS. WKT definition:
PROJCS[
WARNING: Unable to convert input map projection information to GRASS
format.
Same file, same GRASS location.
Google finds 0 results for the string "Pointer 'hSRS' is NULL in
'OSRIsProjected'", so I'm not even sure what project (GRASS, proj, gdal)
might be causing this problem. Sample file is attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3498>
