[GRASS-dev] [GRASS GIS] #3505: Opening a workspace file
Reporter: clerici | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.0
Keywords: | CPU: Unspecified
Platform: Unspecified |
When a saved setting is loaded (Files > Workspace > Open) in my GRASS7.4.0
for Windows, the maps are correctly listed in the Layer Manager and
displayed in the Map Display, but in the Layer Manager no action (delete,
move, etc) is possible on the listed maps.
Platform Windows 8 and Windows 10.
It works on WinGrass 7.2.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505&gt;
  Priority: normal | Milestone: 7.4.1
Component: wxGUI | Version: 7.4.0
Resolution: | Keywords: wingrass
Changes (by martinl):
* keywords: => wingrass
* component: Default => wxGUI
* milestone: => 7.4.1
Comment:
I cannot reproduce this bug on Linux. It's probably Windows related. Can
anyone else on Windows reproduce it?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:1&gt;
Comment (by hellik):
Replying to [comment:1 martinl]:
tested by
System Info
GRASS version: 7.4.0
GRASS SVN revision: r72154
Build date: 2018-01-27
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
and confirmed. moving/deleting layers isn't possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:2&gt;
tested also with
System Info
GRASS version: 7.5.svn
GRASS SVN revision: r72285
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:3&gt;
  Priority: major | Milestone: 7.4.1
       CPU: Unspecified | Platform: MSWindows 8
Changes (by hellik):
* priority: normal => major
* platform: Unspecified => MSWindows 8
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:4&gt;
Comment (by martinl):
Replying to [comment:2 hellik]:
It's not possible to move/delete layers only from open workspace or also
after adding few layers into new workspace?
No traceback in Console?
Reporter claims that this bug is not included in GRASS 7.2.2. It's
strange, there is the same wxPython version, and apparently it's only
Windows related.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:5&gt;
Replying to [comment:5 martinl]:
Windows related.
workflow:
d.rast map=elevation@PERMANENT
d.vect map=streams@PERMANENT color=blue fill_color=blue width=1
d.vect map=firestations@PERMANENT width=1 icon=extra/target size=15
save workspace as g74.gxw
<?xml version="1.0" encoding="cp1252"?>
<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">
<gxw>
     <layer_manager dim="1,1,525,600">
     </layer_manager>
     <display name="Display 1" render="1" mode="0" showCompExtent="0"
alignExtent="1" constrainRes="0" showStatusbar="1" showToolbars="1"
dim="526,1,825,600"
extent="630000.000000,215000.000000,645000.000000,228500.000000,0.000000,1.000000"
tbres="1.000000" viewMode="2d" >
         <layer type="vector" name="firestations@PERMANENT" checked="1"
opacity="1.000000">
             <selected />
             <task name="d.vect">
                 <parameter name="size">
                     <value>15</value>
                 </parameter>
                 <parameter name="map">
                     <value>firestations@PERMANENT</value>
                 </parameter>
                 <parameter name="icon">
                     <value>extra/target</value>
                 </parameter>
                 <parameter name="width">
                     <value>1</value>
                 </parameter>
             </task>
         </layer>
         <layer type="vector" name="streams@PERMANENT" checked="1"
opacity="1.000000">
                 <parameter name="color">
                     <value>blue</value>
                 </parameter>
                     <value>streams@PERMANENT</value>
                 </parameter>
                 <parameter name="fill_color">
                     <value>blue</value>
                 </parameter>
                     <value>1</value>
                 </parameter>
             </task>
         </layer>
         <layer type="raster" name="elevation@PERMANENT" checked="1"
opacity="1.000000">
             <task name="d.rast">
                     <value>elevation@PERMANENT</value>
                 </parameter>
             </task>
         </layer>
     </display>
</gxw>
closing winGRASS7.4.0 session, then re-opening winGRASS7.4.0
opening workspace g74.gxw
=> not possible to move/delete layers from open workspace
then add a new layer
d.vect map=bridges@PERMANENT width=1 icon=extra/bridge size=15
=> not possible to move/delete layers from open workspace **and** not
possible to move/delete new added layer.
no traceback in console
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:6&gt;
set DEBUG=3 and then opened the workspace
C:\>D1/3: G_set_program_name(): g.gisenv
D3/3: G_option_to_separator(): key = separator -> sep = '
D1/3: grass.script.core.start_command(): g.tempfile -d pid=12544
D1/3: G_set_program_name(): g.tempfile
D2/3: G_file_name(): path = D:\grassdata\nc_spm_08_grass7\user1
D2/3: G__temp_element(): .tmp/unknown (tmp=0)
D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\12544.0
D2/3: G_tempfile_pid():
D1/3: grass.script.core.start_command(): g.gisenv -n
D1/3: grass.script.core.start_command(): g.proj -p
D1/3: grass.script.core.start_command(): g.region -ugpc
D1/3: grass.script.core.start_command(): g.findfile -n mapset=user1
file=MASK element=cell
D1/3: G_set_program_name(): g.findfile
D2/3: G_file_name(): path = D:\grassdata\nc_spm_08_grass7\user1\cell\MASK
D1/3: grass.script.core.start_command(): g.region -ugpc s=215000.0
e=645000.0 w=630000.0 n=228500.0
D1/3: grass.script.core.start_command(): g.tempfile pid=12544
D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\12544.1
D1/3: grass.script.core.start_command(): d.rast --q
D1/3: grass.script.core.start_command(): d.vect --q color=blue
map=streams@PERMANENT fill_color=blue width=1
map=firestations@PERMANENT icon=extra/target width=1 size=1D5
D1/3: grass.script.core.start_command(): g.pnmcomp --o opacity=1.0,1.0,1.0
width=807
mask=c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmpya4dnk.pgm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmp8ucbs7.pgm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmphud9ld.pgm
height=501 bgcolor=255:255:255
input=c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmpya4dnk.ppm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmp8ucbs7.ppm,c:\users\myuser\appdata\local\temp\grass7-myuser-11436\tmphud9ld.ppm
output=D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\12544.0.ppm
width=807
width=807
no other debug or traceback
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:7&gt;
Comment (by annakrat):
I think that might have something to do with the changes for compatibility
with wxPython 4. I need more time to investigate this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:8&gt;
In [changeset:"72455" 72455]:
#!CommitTicketReference repository="" revision="72455"
wxGUI: correctly delete layertree, see #3505
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:9&gt;
Could anyone confirm it's working now?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:10&gt;
Replying to [comment:10 annakrat]:
tested with
System Info
GRASS SVN revision: r72553
Build date: 2018-03-24
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
confirmed, moving and deleting layers are working now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:11&gt;
In [changeset:"72624" 72624]:
#!CommitTicketReference repository="" revision="72624"
wxGUI: correctly delete layertree, see #3505 (merge from trunk, r72455)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3505#comment:13&gt;
