GDAL
March 2, 2018, 3:09pm
1
#3508: grass start up: buggy to_text_string
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Startup | Version: svn-trunk
Keywords: wingrass, unicode | CPU: Unspecified
Platform: Unspecified |
GRASS fails even start on Windows when username contains non-ascii
characters
File "C:\Program Files\GRASS GIS 7.4.0\etc\grass74.py", line 2003, in
<module>
main()
File "C:\Program Files\GRASS GIS 7.4.0\etc\grass74.py", line 1854, in
main
set_paths(grass_config_dir=grass_config_dir)
File "C:\Program Files\GRASS GIS 7.4.0\etc\grass74.py", line 620, in
set_paths
os.environ['MANPATH'] = to_text_string(addons_man_path)
File "C:\Program Files\GRASS GIS 7.4.0\Python27\lib\os.py", line 420, in
__setitem__
putenv(key, item)
UnicodeEncodeError: 'ascii' codec can't encode character u'\u017e' in
position 10: ordinal not in range(128)
Press any key to continue . . .
When I change line source:grass/trunk/lib/init/grass.py#L620
to
os.environ['MANPATH'] = addons_man_path
then GRASS starts and even MANPATH variable is set up correctly (including
non-ascii characters). Function `to_text_string` is apparently buggy.
Tested on Czech (cp1250) Windows 8.1.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
March 2, 2018, 3:15pm
2
Priority: blocker | Milestone: 7.2.3
Resolution: | Keywords: wingrass, unicode
Changes (by martinl):
* priority: normal => blocker
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:1> ;
GDAL
March 2, 2018, 3:18pm
3
Comment (by martinl):
`to_text_string` has been introduced 3 years ago in r65780
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:2> ;
GDAL
March 2, 2018, 3:20pm
4
Comment (by wenzeslaus):
Right. The code is similar to `_get_encoding()/decode()/encode()` group in
source:grass/trunk/lib/python/script/utils.py#L159 from r65787. Do these
functions work for you (assuming you can get around the startup issue)?
All is basically based around `locale.getdefaultlocale()[1]`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:3> ;
GDAL
March 2, 2018, 3:35pm
5
Comment (by mlennert):
I think this is a classical case of it being better not to mess around
with the original byte string. All we do is taking a string from an
environment variable, adding two new path elements and putting it back
into another environment variable:
addon_base = os.getenv('GRASS_ADDON_BASE')
addons_man_path = os.path.join(addon_base, 'docs', 'man')
Do we really have to worry about encoding/decoding in that context ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:4> ;
GDAL
March 3, 2018, 9:09am
6
Replying to [comment:4 mlennert]:
Encoding/decoding doesn't seems to be needed in this case.
perfectly works on my testing computer.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:5> ;
GDAL
March 3, 2018, 10:10am
7
Comment (by hellik):
Replying to [comment:5 martinl]:
a related ticket: #3500
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:6> ;
GDAL
March 16, 2018, 12:07pm
8
In [changeset:"72374" 72374]:
#!CommitTicketReference repository="" revision="72374"
disable to_text_string() in grass.py, see #3508
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:7> ;
GDAL
March 16, 2018, 12:08pm
9
`to_text_string()` disabled in r72374. Planning backport to 7.4 and 7.2
branches, any objections?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:8> ;
GDAL
March 18, 2018, 5:41pm
10
Replying to [comment:8 martinl]:
None from me.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:9> ;
GDAL
March 20, 2018, 10:52am
11
In [changeset:"72401" 72401]:
#!CommitTicketReference repository="" revision="72401"
disable to_text_string() in grass.py, see #3508 (merge r72374 from trunk)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:10> ;
GDAL
March 20, 2018, 11:00am
12
In [changeset:"72402" 72402]:
#!CommitTicketReference repository="" revision="72402"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:11> ;
GDAL
March 20, 2018, 11:05am
13
Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, unicode
* status: new => closed
* resolution: => fixed
Comment:
Fixed in all affected branches: grass74 and grass72.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3508#comment:12> ;
