[GRASS-dev] [GRASS GIS] #3511: [patch] v.buffer: allow squared buffers around points
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.4.1
Component: Vector | Version: svn-trunk
Keywords: v.buffer squared buffer | CPU: Unspecified
Platform: Unspecified |
The attached patch implements squared buffers around points.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511&gt;
Resolution: | Keywords: v.buffer squared buffer
Changes (by mlennert):
* Attachment "squared_buffer_around_points.diff" added.
Comment (by mlennert):
Replying to [ticket:3511 mlennert]:
Forgot to explain: with the patch, v.buffer should create square buffers
around points if the -s flag is set.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:1&gt;
Comment (by mmetz):
Replying to [comment:1 mlennert]:
Currently v.buffer always uses Vect_point_buffer2() for points, but the
Vect_*_buffer*() functions might disappear at some stage because they are
not working properly (apart from point buffering). Therefore it might be
safer to add this functionality to v.buffer directly.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:2&gt;
* Attachment "squared_buffer_around_points_directly_in_vbuffer.diff"
added.
second version of a patch, this time directly in main.c of v.buffer
Replying to [comment:2 mmetz]:
buffers around points if the -s flag is set.
Please check the attached new patch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:3&gt;
Comment (by mmetz):
Replying to [comment:3 mlennert]:
the Vect_*_buffer*() functions might disappear at some stage because they
are not working properly (apart from point buffering). Therefore it might
be safer to add this functionality to v.buffer directly.
The patch looks and works fine, please commit.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:4&gt;
Replying to [comment:4 mmetz]:
Done in r72353.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:5&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: v.buffer squared buffer
* status: new => closed
* resolution: => fixed
Comment:
Closing this ticket as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3511#comment:6&gt;
