GDAL
March 17, 2018, 2:59pm
1
#3514: Read EPSG codes with PROJ v.5 fails
Reporter: nila | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Startup | Version: unspecified
Keywords: PROJ_v.5 epsg startup | CPU: Unspecified
Platform: All |
As of version 5 of PROJ , the epsg file starts with a '<metadata>...'
line. The current code in gui::wxpython::core::utils.py::ReadEpsgCodes
doesn't take this into account.
This causes e.g. the creation of a new location in the startup based on
epsg code to fail.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
March 19, 2018, 12:38pm
2
Priority: major | Milestone: 7.0.7
Resolution: | Keywords: PROJ_v.5 epsg startup
CPU: Unspecified | Platform: All
Changes (by martinl):
* milestone: => 7.0.7
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:1> ;
GDAL
March 19, 2018, 12:47pm
3
Comment (by rsbivand):
This is what I did in rgdal::make_EPSG():
[https://r-forge.r-project.org/scm/viewvc.php?view=rev&root=rgdal&revision=702 ]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:2> ;
GDAL
March 19, 2018, 1:57pm
4
Comment (by martinl):
In [changeset:"72392" 72392]:
#!CommitTicketReference repository="" revision="72392"
Read EPSG codes with PROJ v.5 fails, see #3514
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:3> ;
GDAL
March 19, 2018, 1:59pm
5
Should be fixed in r72392 (trunk). Testing highly welcome before we do
backport to release branches.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:4> ;
GDAL
6
Reporter: nila | Owner: martinl
Type: defect | Status: assigned
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* status: new => assigned
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:5> ;
GDAL
March 19, 2018, 2:21pm
7
Comment (by nila):
Thanks! Works fine for me on 7.4.0 under macOS, in Startup and
Preferences. Tested with the old type of epsg file as well as the new one.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:6> ;
GDAL
March 22, 2018, 3:16pm
8
Priority: major | Milestone: 7.4.1
* milestone: 7.0.7 => 7.4.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:7> ;
GDAL
March 22, 2018, 3:18pm
9
Type: defect | Status: closed
Resolution: fixed | Keywords: PROJ_v.5 epsg startup
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"72494" 72494]:
#!CommitTicketReference repository="" revision="72494"
Read EPSG codes with PROJ v.5 fails, fix #3514
Ticket URL: <https://trac.osgeo.org/grass/ticket/3514#comment:8> ;
