#352: r.in.gdal region troubles in LL
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.6
Component: Raster | Version: unspecified
Resolution: | Keywords: r.in.gdal
Comment (by mmetz):
Replying to [comment:3 glynn]:
> Replying to [comment:2 neteler]:
> > The user took this map
> > and passed it to R, and then redefined:
> > and then he wrote b as npp.tif using the QGIS plugin manageR.
> > Maybe there is a precision issue before, somwhere in the R or QGIS
part?
> It appears so. The inaccuracy is present in the TIFF file; it isn't
being introduced by libtiff, GDAL or GRASS.
The example file npp.tif is no longer existing. The problem can be
reproduced with
g.region n=85.000000000114397 \
s=-58.000000000000007 \
e=180.000000000288 \
w=-180 rows=572 cols=1440 -p
In GRASS 7.2, this gives
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 85N
south: 58S
west: 180W
east: 179:59:59.999999W <-- wrong EW extent of 0.000001 seconds
nsres: 0:15
ewres: 0 <-- invalid because of wrong east
rows: 572
cols: 1440
cells: 823680
A subsequent `g.region -p` gives
ERROR: Syntax error in cell header
In trunk, setting the region as above gives
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 85N
south: 58S
west: 180W
east: 180:00:00.000001E <-- ok
nsres: 0:15
ewres: 0:15 <-- ok
rows: 572
cols: 1440
cells: 823680
The EW extent is now slightly (0.000001 seconds) larger than 360 degrees,
but g.region does not complain and east is easy to fix.
Ticket URL: <https://trac.osgeo.org/grass/ticket/352#comment:6>
