[GRASS-dev] [GRASS GIS] #3521: wxGUI datacatalog: allow actions on multiple selected files
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: unspecified
Keywords: datacatalog | CPU: Unspecified
Platform: Unspecified |
In the current datacatalog in the trunk wxGUI, you can select a map and
then perform actions such as cut, copy, delete on that map. However, it is
not possible to select several maps to perform the action on the entire
batch.
It would be great if that were possible. :slight_smile:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3521&gt;
  Priority: normal | Milestone: 7.6.2
Resolution: | Keywords: datacatalog
Comment (by wenzeslaus):
For some time that's possible at least in master (7.9). (The milestone may
need to be changed.) Please check if it works as expected. You can
reproject multiple maps.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3521#comment:3&gt;
