#3532: g.gui.tplot: add zonal statistics support
Reporter: veroandreo | Owner: grass-dev@…
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.tplot, temporal, zonal | CPU: Unspecified
statistics |
Platform: Linux |
It would be very nice to have zonal statistics support in G7:g.gui.tplot
to get time series plots representing areas. Currently, for STRDS, only
time series of pixels are supported.
Additionally, it would be nice to have a flag/check-box to get the
standard deviation plotted as well.
The attached diff implements support for r.univar to calculate statistic
for a vector map used as MASK.
Right now only mean value is used because there is a problem with a
gselect.ElementSelect, the element seems to be disabled, could some one
check it, because I don't understand where is the error. I also tested
Enable function but it doesn't change the behaviour.
