#3548: sql where statement encoding issue on windows
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.4.1
Component: Database | Version: 7.4.0
Keywords: select, where, wingrass, encoding | CPU: Unspecified
Platform: Unspecified |
SQL WHERE statements with diacritics on Windows return no records. It
seems to be a bug. Same command performed in GRASS GUI (no record, wrong)
and SQLiteBrowser (one record, correct), see
attachment:grass_bug_windows_db_select.png. It seems to be encoding issue,
tested with Czech Windows 8.1 localization (cp1250). Strangely, records
with diacritics appear correct in GRASS GUI, see
Resolution: | Keywords: select, where, wingrass, encoding
Description changed by martinl:
Old description:
issue, tested with Czech Windows 8.1 localization (cp1250). Strangely,
records with diacritics appear correct in GRASS GUI, see
New description:
and SQLiteBrowser (one record, correct). See
It seems to be encoding issue, tested with Czech Windows 8.1 localization
(cp1250). Strangely, records with diacritics appear correct in GRASS GUI.
See
