[GRASS-dev] [GRASS GIS] #355: ps.map generates invalid postscript when vlegend item does not appear on map
map
Reporter: scottygamm | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: default | Version: 6.3.0
Keywords: | Platform: MSWindows CygWin
      Cpu: x86-32 |
I have a map control file that generates several (21) vareas with pattern
fill and defines label and lpos entries for the legend. As it happens,
one of those vareas does not appear on the map area. As a result, the
postscript output omits the dictionary entry for that pattern. When
vlegend generates the legend output, it attempts to reference the missing
pattern definition (of the form APATTEPSnn) and applications that try to
render the postscript fail in various ways. Workaround is to omit the
vareas causing the problem. I have not included files but can provide
them if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/355&gt;
I encountered the same problem a couple of weeks ago. I was able to get
around it by adding the following to ps_vlegend.c around line 172 ...
pat_save ( PS.fp, vector.layer[i].pat, pat);
Insert this line after "sprintf ( pat, "APATTEPS%d", i);" to ensure the
pattern definition is saved.
Hope this helps.
Bob
map
      Cpu: x86-32 |
them if needed.
grass-dev mailing list
map
Resolution: | Keywords:
  Platform: MSWindows CygWin | Cpu: x86-32
Comment (by neteler):
Replying to [ticket:355 scottygamm]:
to ensure the pattern definition is saved.
Hope this helps.
Bob
Ticket URL: <http://trac.osgeo.org/grass/ticket/355#comment:1&gt;
map
  Reporter: scottygamm | Owner: hamish
      Type: defect | Status: assigned
Changes (by hamish):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => hamish
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/355#comment:2&gt;
map
Component: ps.map | Version: 6.3.0
  * component: default => ps.map
Ticket URL: <http://trac.osgeo.org/grass/ticket/355#comment:3&gt;
map
  Priority: minor | Milestone: 6.4.0
  * milestone: 6.3.1 => 6.4.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/355#comment:4&gt;
map
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
* cc: casey.vandenberg@sjgeophysics.com, bcovill@tekmap.ns.ca (added)
  * resolution: => fixed
Comment:
patch applied in SVN, thanks!
I also fixed the vector legend bug reported by Casey Vandenberg on Nov 20
where it wouldn't let you place the vector legend to the left of the map
box. Now you can go as far as the left margin. The right side of the
legend (for multicolumn) is still rather unconstrained, I've left it as
not starting a new column past the right side of the map box, which seems
like a fair compromise. Feel free to post a patch doing that better if you
can figure out how.. I don't think it is easily possible to improve on the
current way.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/355#comment:5&gt;
map
Comment (by hamish):
Replying to [comment:5 hamish]:
20 where it wouldn't let you place the vector legend to the left of the
map box. Now you can go as far as the left margin. The right side of the
current way.
actually it was easy. I've now added a new vlegend "span" command to let
you set the legend column spacing.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/355#comment:6&gt;
