#3551: Please use env vars instead of cmd line parameters for credentials
Reporter: frankie | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
Note that username and password are visible to all users by using simple
commands which list running processes. That is not a good thing o do, it
would be better using a pair of environment variables instead.
Resolution: | Keywords:
Comment (by marisn):
It's not that easy. Setting env variables for Windows users is not so
common as for *nix'ers. IMHO a correct solution would be to accept both –
env variables and command line parameters + add an explanation in
documentation. Thus on typical single user Windows boxes nothing would
change, but multiuser *nix users will be able to not expose their
credentials by using env vars.
