#3553: i.superpixels.slic: can seed initialization warning be transformed into a
message ?
Reporter: mlennert | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: i.superpixels.slic warning | CPU: Unspecified
Platform: Unspecified |
When running i.superpixels.slic, generally with the step parameter set, I
systematically get a warning of the type:
WARNING: Initialized 9619 of 24804 seeds
Any reason this has to be a warning (which makes output very verbose)
instead of a message which can easily be suppressed with --q ?
message ?
Resolution: | Keywords: i.superpixels.slic warning
Comment (by mmetz):
Replying to [ticket:3553 mlennert]:
I systematically get a warning of the type:
There is not really a reason why this should be a warning. Changed in
r73316.
message ?
Comment (by mlennert):
Replying to [comment:1 mmetz]:
set, I systematically get a warning of the type:
r73316.
Thanks !
Any opposition to backporting this at least to release76 ?
message ?
Type: enhancement | Status: closed
Resolution: fixed | Keywords: i.superpixels.slic warning
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:2 mlennert]:
verbose) instead of a message which can easily be suppressed with --q ?
r73316.
> Thanks !
As this is an addon, this remark was obviously nonsense. Sorry for the
noise.
