[GRASS-dev] [GRASS GIS] #3564: Inconsistent results from qsort callback in g.mkfontcap
Reporter: yugr | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.0
Keywords: | CPU: All
Platform: All |
qsort callback compare_fonts in g.mkfontcap may return invalid result when
arguments are swapped. Such bugs may causes inconsistent order or even
crashes in some qsort implementations
(​https://bugzilla.samba.org/show_bug.cgi?id=3959).
The issue has been detected when running standard testsuite under
SortChecker? (​https://github.com/yugr/sortcheck):
   g.mkfontcap[15109]: qsort: comparison function is not symmetric
(comparison function 0x4023c0 (/build/grass-7.0.3/dist.x86_64-pc-linux-
gnu/bin/g.mkfontcap+0x4023c0), called from 0x4017a8
(/build/grass-7.0.3/dist.x86_64-pc-linux-gnu/bin/g.mkfontcap+0x4017a8),
cmdline is "/build/grass-7.0.3/dist.x86_64-pc-linux-gnu/bin/g.mkfontcap
-s")
Problem is in lines
     if (aa->type != bb->type)
         return (aa->type > bb->type);
which should be replaced with something like
         return (aa->type > bb->type) ? 1 : -1;
As a side note, many qsort callbacks in Grass are vulnerable to integer
overflows e.g. cmp_edge in ./lib/vector/neta/spanningtree.c:
     return ((edge_cost_pair *) pa)->cost - ((edge_cost_pair *) pb)->cost;
or longcmp in ./raster/r.kappa/prt_mat.c:
     return (*a - *b);
and many many others.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564&gt;
  Priority: normal | Milestone: 7.6.0
Resolution: | Keywords: qsort callback
       CPU: All | Platform: All
Changes (by mmetz):
* keywords: => qsort callback
* milestone: => 7.6.0
Comment:
Replying to [ticket:3564 yugr]:
> Hi,
when arguments are swapped. Such bugs may causes inconsistent order or
even crashes in some qsort implementations
-s")
> Problem is in lines
Fixed in trunk r72727.
pb)->cost;
Fixed in trunk r72728.
> return (*a - *b);
Fixed in trunk r72729.
If you already have a list of these many other problems, can you provide
such a list? That would be very helpful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:1&gt;
Comment (by yugr):
Hi Markus,
I wasn't sure you'd be interested in these potential overflows (e.g. some
may be highly unlikely due to small subtracted values) so didn't report
them in first comment.
There you go (found by manual analysis of source code):
   static int cmp_edge(const void *pa, const void *pb)
./lib/vector/Vlib/break_lines.c
   static int cmp(const void *a, const void *b)
     int ai = *(int *)a;
     int bi = *(int *)b;
     return (ai - bi);
./raster/r.distance/edges.c
   static int cmp(const void *aa, const void *bb)
     const struct CatEdgeList *a = aa, *b = bb;
     return (int)(a->cat - b->cat);
   static int longcomp(const void *aa, const void *bb)
     const long *a = aa;
     const long *b = bb;
     return (*a - *b);
./raster/r.stats/stats.c
   static int node_compare(const void *pp, const void *qq)
     struct Node *const *p = pp, *const *q = qq;
     register int i, x;
     register const CELL *a, *b;
     a = (*p)->values;
     b = (*q)->values;
     for (i = nfiles; --i >= 0;)
         if (x = (*a++ - *b++), x)
             return x;
     return 0;
./raster/r.what/main.c
   static int by_row(const void *ii, const void *jj)
     const struct order *i = ii, *j = jj;
     return i->row - j->row;
./vector/v.generalize/misc.c
     int ai = *(int *)a;
     int bi = *(int *)b;
     return (ai - bi);
./vector/v.overlay/area_area.c
   static int cmp_int(const void *a, const void *b)
     return (*(int *)a - *(int *)b);
./vector/v.to.rast/support.c
   static int cmp_labels_i(const void *a, const void *b)
     struct My_labels_rule *al = (struct My_labels_rule *) a;
     struct My_labels_rule *bl = (struct My_labels_rule *) b;
     return (al->i - bl->i);
./vector/v.vect.stats/main.c
   static int cmp_area(const void *pa, const void *pb)
     AREA_CAT *p1 = (AREA_CAT *) pa;
     AREA_CAT *p2 = (AREA_CAT *) pb;
     return (p1->area_cat - p2->area_cat);
./vector/v.what.rast/search.c
./vector/v.what.rast3/search.c
   /* for qsort, order list by row */
   /* for qsort, order list by cat */
   int by_cat(const void *ii, const void *jj)
     return i->cat - j->cat;
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 yugr]:
> Hi Markus,
provide such a list? That would be very helpful.
some may be highly unlikely due to small subtracted values) so didn't
report them in first comment.
I am interested. The comparison in g.mkfontcap was wrong, it returned 0
when it should return -1. The comparison in r.kappa was clearly dangerous
because it converted long to int. The remaining cases need to be checked
individually: if the integers to be subtracted are always positive,
integer overflow can not happen.
Thanks for the list!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:3&gt;
Comment (by yugr):
One more symmetry issue in ./vector/v.profile/main.c:
   static int compdist(const void *d1, const void *d2)
     if (r1->distance > r2->distance)
         return 1;
     else
         return -1;
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:4&gt;
Comment (by mmetz):
In [changeset:"73135" 73135]:
#!CommitTicketReference repository="" revision="73135"
v.profile: fix qsort cmp fn (see #3564)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:5&gt;
Comment (by mmetz):
In [changeset:"73136" 73136]:
#!CommitTicketReference repository="" revision="73136"
r.what: fix qsort cmp fn (see #3564)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:6&gt;
Comment (by mmetz):
In [changeset:"73137" 73137]:
#!CommitTicketReference repository="" revision="73137"
r.stats: fix qsort cmp fn (see #3564)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:7&gt;
Comment (by mmetz):
In [changeset:"73138" 73138]:
#!CommitTicketReference repository="" revision="73138"
r.kappa: fix qsort cmp fn (see #3564)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:8&gt;
Comment (by mmetz):
In [changeset:"73139" 73139]:
#!CommitTicketReference repository="" revision="73139"
r.distance: fix qsort cmp fn (see #3564)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:9&gt;
Comment (by mmetz):
In [changeset:"73140" 73140]:
#!CommitTicketReference repository="" revision="73140"
Vlib: add comment to qsort cmp fn (see #3564)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: qsort callback
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
All instances of possible inconsistent results or potential buffer
overflow have been fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:11&gt;
      Type: defect | Status: reopened
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
Do(n't) we want a bulk backport? If yes, I can do that
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:12&gt;
  Priority: normal | Milestone: 7.4.2
Changes (by mmetz):
* status: reopened => closed
* milestone: 7.6.0 => 7.4.2
Comment:
Replying to [comment:12 neteler]:
Backported to relbr74 with r73145.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:13&gt;
