[GRASS-dev] [GRASS GIS] #3567: v.select: doubtful result with the default overlap operator selecting areas with lines
with lines
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.2
Component: Vector | Version: svn-trunk
Keywords: v.select overlap | CPU: Unspecified
Platform: Unspecified |
Trying to select areas with lines, I get a result using the overlap
operator that I don't really understand, and which I suspect being a bug.
Using the following command in the attached location, test_vselect mapset:
v.select ain=test_polys bin=test_line atype=area btype=line
out=result_overlap op=overlap
I get a result of only three areas selected (see attached map) where,
IMHO, all 41 should be.
I'll try to diagnose this further when I have the time...
The attached location includes the results of runs with op=intersects,
op=crosses and op=overlaps which provide the results I expect.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567&gt;
with lines
Resolution: | Keywords: v.select overlap
Changes (by mlennert):
* Attachment "loc_test_vselect.tgz" added.
location with test data in mapset test_vselect
with lines
* Attachment "v_select_issue_with_overlap_operator.png" added.
image of overlap results
with lines
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.select overlap
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"72746" 72746]:
#!CommitTicketReference repository="" revision="72746"
Vlib: fix with_z = 0 for Vect_line_check_intersection2() and
Vect_line_intersection2(), fixes #3567
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:1&gt;
with lines
Comment (by mmetz):
In [changeset:"72747" 72747]:
#!CommitTicketReference repository="" revision="72747"
Vect_line_intersection2(), fixes #3567 (backport trunk r72746)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:2&gt;
with lines
Comment (by mmetz):
Replying to [ticket:3567 mlennert]:
mapset:
The problem was not the overlap operator of v.select, but instead that the
vector test_line is 3D, and one of the underlying library functions did
not ignore z as it should have done. This bug has been fixed in trunk and
relbr74 with r72746,7.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:3&gt;
with lines
Comment (by mlennert):
Replying to [comment:3 mmetz]:
mapset:
the vector test_line is 3D, and one of the underlying library functions
did not ignore z as it should have done. This bug has been fixed in trunk
and relbr74 with r72746,7.
Thanks a lot ! Sorry, should have noticed the 3D nature of the vector
myself. I guess there must have been a message at import which I didn't
see.
This obviously raises the question of whether v.select should always
ignore 3D or whether a flag (-3) should allow enabling it so that if one
wants to check spatial relation in 3D this is possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:4&gt;
with lines
Comment (by mmetz):
Replying to [comment:4 mlennert]:
mapset:
where, IMHO, all 41 should be.
see.
This is not possible because `Vect_segment_intersection()` does not
support 3D coordinates.
Also note that 3D topology does not exist yet in GRASS, e.g. a purely
vertical line can cause problems, because it is marked as degenerate at
the corresponding nodes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:5&gt;
with lines
  Priority: normal | Milestone: 7.4.1
Changes (by neteler):
* milestone: 7.4.2 => 7.4.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567#comment:6&gt;
