[GRASS-dev] [GRASS GIS] #3568: g.remove: add option file as in t.remove
Reporter: veroandreo | Owner: grass-dev@…
Priority: normal | Milestone: 7.6.0
Component: Default | Version: svn-trunk
Keywords: g.remove, file option | CPU: Unspecified
Platform: Unspecified |
A `file` parameter would be useful in G7:g.remove for the cases in which
one needs to remove files that do not match a pattern. G7:t.remove has
such a parameter, for example.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3568&gt;
      Type: enhancement | Status: closed
Resolution: invalid | Keywords: g.remove, file option
Changes (by veroandreo):
* status: new => closed
* resolution: => invalid
Comment:
Ops, I missed the point that the comma separated list of such files can be
passed in the `name` option. Too used to `file`. Sorry...
Closing as invalid since the required functionality is already there, my
bad.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3568#comment:1&gt;
