[GRASS-dev] [GRASS GIS] #3569: pyGRASS: vector attributes return None
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.2
Component: PyGRASS | Version: unspecified
Keywords: VectorTopo, attributes table | CPU: All
Platform: All |
If you try to open a vector map in a Mapset different from the current it
seems not possible to read attributes. Running the following code from
user1 mapset of nc_spm_08
#counties = VectorTopo('boundary_county')
counties = VectorTopo('boundary_county', mapset='PERMANENT')
counties.open('r')
first = counties[1]
first
first.attrs.values()
Ticket URL: <https://trac.osgeo.org/grass/ticket/3569&gt;
Resolution: | Keywords: VectorTopo, attributes table
       CPU: All | Platform: All
Description changed by neteler:
Old description:
counties.open('r')
first = counties[1]
first
New description:
from grass.pygrass.vector import VectorTopo
counties.open('r')
first = counties[1]
first
   File "<stdin>", line 1, in <module>
AttributeError: 'NoneType' object has no attribute 'values'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3569#comment:1&gt;
Comment (by neteler):
Confirmed in trunk (I used r73241)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3569#comment:2&gt;
