[GRASS-dev] [GRASS GIS] #3570: g.remove dialog does not allow user to select map(s)
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: g.remove, wxgui | CPU: Unspecified
Platform: Unspecified |
Weirdly, the map selection dialog only gives "no selectable item"
regardless of whether a map type is selected. This only seems a problem in
7.5 svn.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570&gt;
Resolution: | Keywords: g.remove, wxgui
Comment (by cmbarton):
This is NOT related to a recent fix of pull down controls. I checked and
it is also a problem in 7.5 compiled in April.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:1&gt;
Comment (by annakrat):
In [changeset:"72786" 72786]:
#!CommitTicketReference repository="" revision="72786"
wxGUI: replace deprecated checkbox event method, see #3570
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:2&gt;
I don't quite understand the comment 2. Does that mean the problem is
fixed in 72786 or caused by 72786? The referenced ticket is this one here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:3&gt;
That comment is automated message when you commit and mention the ticket
number in the commit message. So r72786 should fix this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:4&gt;
OK. Thanks. I'll compile 7.5 again next week to test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.remove, wxgui
Changes (by cmbarton):
* status: new => closed
* resolution: => fixed
Comment:
Just recompiled. This is now fixed. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3570#comment:6&gt;
