[GRASS-dev] [GRASS GIS] #3571: 3D raster map not displayed in 3D view mode in winGRASS
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: Raster3D | Version: 7.4.0
Keywords: | CPU: x86-64
Platform: MSWindows 8 |
calculating a 3D raster map by following the
[https://grass.osgeo.org/grass75/manuals/v.vol.rst.html v.vol.rst-example]
g.region -3
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928100
south: 4913700
west: 589900
east: 609000
top: 1500.00000000
bottom: 0.00000000
nsres: 100
nsres3: 100
ewres: 100
ewres3: 100
tbres: 100
rows: 144
rows3: 144
cols: 191
cols3: 191
depths: 15
cells: 27504
cells3: 412560
r3.colors --verbose map=soilrange@user1 color=viridis
Color table for raster3d map <soilrange@user1> set to 'viridis'
r3.info map=soilrange@user1
  | Layer: soilrange@user1 Date: Sat Jun 02 20:57:10 2018
  | Mapset: user1 Login of Creator: hkmyr
  | DataBase: D:\grassdata
  | Title: soilrange
  | Units: none
  | Vertical unit: units
  | Timestamp: none
  | Type of Map: raster_3d Number of Categories: 0
  | Data Type: FCELL
  | Rows: 144
  | Columns: 191
  | Depths: 15
  | Total Cells: 412560
  | Total size: 763629 Bytes
  | Number of tiles: 72
  | Mean tile size: 10605 Bytes
  | Tile size in memory: 24576 Bytes
  | Number of tiles in x, y and z: 6, 6, 2
  | Dimension of a tile in x, y, z: 32, 24, 8
  | Projection: UTM (zone 13)
  | N: 4928100 S: 4913700 Res: 100
  | E: 609000 W: 589900 Res: 100
  | T: 1500 B: 0 Res: 100
  | Range of data: min = -0.00299961 max = 7.1888442
  | Data Source:
  | Data Description:
  | generated by v.vol.rst
  | Comments:
  | v.vol.rst input="elevrand_3d" wcolumn="soilrange" tension=40.
smooth\ |
  | =0.1 segmax=50 npmin=200 npmax=700 wscale=1.0 zscale=100
elevation="\ |
  | soilrange"
g.gisenv set=DEBUG=3
some errors found when loading the 3D raster in 3D view mode
D3/3: region item: depths: 15
D3/3: region item: e-w resol3: 100
D3/3: region item: n-s resol3: 100
D3/3: region item: t-b resol: 100
D1/3: GS_libinit(): n=4928100.000000 s=4913700.000000 w=589900.000000
e=609000.000000 scale=0.052356 first=0
D3/3: G_str_to_color(): str = '255:255:255'
D3/3: GS_get_zrange_nz(): min=0 max=0
   File "C:\OSGEO4~1\apps\grass\grass-7.5.svn\gui\wxpython\nviz\tools.py",
line 4339, in OnVolumeResolution
     self.SetVolumeResolution(event.GetInt())
line 4344, in SetVolumeResolution
     id = data['object']['id']
KeyError: 'object'
line 3274, in OnSetRaster3D
     self.UpdateVolumePage(layer, data, updateName=False)
line 5543, in UpdateVolumePage
KeyError: 'object'
D1/3: Nviz_change_exag(): value = 1.000000
D3/3: GS_global_exag(): 1
D1/3: Nviz_set_viewpoint_height(): value = 5000.000000
D3/3: GS_get_zrange(): min=8.71087e-039 max=0
the 3D raster map isn't displayed in 3D view mode.
tested in winGRASS7.4.0
and
System Info
GRASS version: 7.5.svn
GRASS SVN revision: r72754
Build date: 2018-06-01
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3571&gt;
  Priority: major | Milestone: 7.4.1
Resolution: | Keywords:
       CPU: x86-64 | Platform: MSWindows 8
Changes (by hellik):
* priority: normal => major
Ticket URL: <https://trac.osgeo.org/grass/ticket/3571#comment:1&gt;
Comment (by hellik):
see also a corresponding thread in the [http://osgeo-
org.1560.x6.nabble.com/3D-raster-color-coding-td5366112.html user ML]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3571#comment:2&gt;
