#3576: Show recent GRASS Databases in the Data tab
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: normal | Milestone: 8.0.0
Component: wxGUI | Version: unspecified
Keywords: datacatalog, dbase, gisdbase | CPU: Unspecified
Platform: Unspecified |
The Data tab shows only the current GRASS (GIS) database (directory). Some
users have two or more of these "grassdata" directories, so moving data
between then should be possible. For example, r.proj already allows that
(`dbase` option).
The additional databases/directories could be added manually to cover all
the cases, but perhaps just putting there n recent ones would suffice to
most users.
To avoid some long loading times, maybe only the current
database/directory tree should be loaded and the other(s) should be loaded
on demand, e.g., with context menu (this may lead to unexpected
situations, e.g., with search).
Also useful if the Data tab/data catalog functionality is reused for the
startup window.
Depends on:
* #572 Remember recent GIS Data Directory
Ticket URL: <https://trac.osgeo.org/grass/ticket/3576>
