#3577: Add rename and delete of Location and Mapset in Datacatalog
Reporter: wenzeslaus | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 8.0.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: datacatalog, location, mapset,
CPU: | rename, delete, move, remove, g.mapset
Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* keywords: datacatalog, location, mapset, rename, delete, move, remove =>
datacatalog, location, mapset, rename, delete, move, remove, g.mapset
Comment:
Probably not `g.remove mapset` because mapset is (at least currently) not
considered to be an element (''element of a mapset'' to be exact) like
raster or vector maps.
`g.mapset -r` is difficult to decide. It looks like it makes sense, but on
the other hand, in GRASS GIS, you are not allowed to edit data in other
mapsets. Deleting other mapset seems to qualify as editing data in other
mapset and deleting current mapset does not make much sense.
Nevertheless, now (in the startup) you can do it (you are not really
running GRASS yet). It is implemented purely in GUI/Python (AFAIR). It is
important for the users who are not using command line and can't use `rm
/the/full/path/to/mapset` or are not confident about the database
directory structure to simply navigate there in a file browser and delete
it.
Adding rename and delete (of location and mapset) to Datacatalog is an
extension of functionality in Startup window and in the Data tab (which is
here to be nice towards users without deeper GRASS GIS knowledge or
command line knowledge). Another reason for it that the Datacatolog (in a
modified) is a candidate for inclusion into the new Startup window.
Ideally, the functionality of Datacatalog will be configurable on the code
level (so different things can be enabled). There is already runtime
configuration, namely unlocking of editing of other mapsets (third button
from left - lock which is a toggle).
Thus, I would keep this ticket to be just about the Datacatalog, so if you
want to pursue CLI/module-level API for removing mapsets (and locations),
please open a new ticket (if it is okay with you). The fact that the
functionality is in the GUI is definitively an argument for having it also
in the command line (whether it is in a module or in the `grass`
executable).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3577#comment:2>
