[GRASS-dev] [GRASS GIS] #358: new flag for r.quantile to produce output compatible with r.recode
Reporter: dylan | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Keywords: r.quantile | Platform: All
      Cpu: All |
Small patch to re-format output from r.quantile. Default output looks like
this
r.quantile in=beam_150 quantiles=5
0:20.000000:7440.040527
1:40.000000:7512.872559
2:60.000000:7611.160645
3:80.000000:7611.161133
Modified output:
r.quantile in=beam_150 quantiles=5 -r
6429.886230:7440.040527:1
7440.040527:7512.872559:2
7512.872559:7611.160645:3
7611.160645:7611.161133:4
7611.161133:7638.599121:5
Patch is attached.
Ticket URL: <http://trac.osgeo.org/grass/ticket/358&gt;
Resolution: | Keywords: r.quantile
  Platform: All | Cpu: All
Comment (by glynn):
Replying to [ticket:358 dylan]:
> Patch is attached.
I've committed a modified version of this as r34219 (7.0). The behaviour
is identical, but the resulting diff is a bit simpler.
Ticket URL: <http://trac.osgeo.org/grass/ticket/358#comment:1&gt;
Comment (by glynn):
> Patch is attached.
Thanks Glynn. I figured this would be universally useful. How hard
would be it be to apply this to the 6.4 branch?
Dylan
On Mon, Nov 10, 2008 at 6:38 AM, Dylan Beaudette
Comment (by glynn):
> Patch is attached.
As simple as
svn merge -c 34219 https://svn.osgeo.org/grass/grass/trunk
Done.
>>---- Reporter: dylan | Owner: grass-dev@lists.osgeo.org
>>---- Comment (by glynn):
>> > Patch is attached.
>> behaviour is identical, but the resulting diff is a bit simpler.
As simple as
Done.
Thanks Markus, and thanks to Glynn for adding r.quantile!
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
