[GRASS-dev] [GRASS GIS] #359: r.quantile computes incorrect values with default number of bins
Reporter: dylan | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: r.quantile | Platform: Linux
      Cpu: x86-32 |
I noticed that when computing quantiles from a highly skewed distribution,
incorrect values are returned with the default number of bins. Reducing
the number of bins seems to correct the problem
Example, based on attached raster file in GRASS ASCII format:
r.quantile in=beam_150 quantiles=5
0:20.000000:7440.040527
1:40.000000:7512.872559
2:60.000000:7611.160645
3:80.000000:7611.161133
r.quantile in=beam_150 quantiles=5 bins=10')
2:60.000000:7570.587402
Quantiles computed in R:
library(spgrass6)
x <- readRAST6('beam_150')
quantile(x@data$beam_150, prob=c(0,0.2,0.4,0.6,0.8,1), na.rm=TRUE)
       0% 20% 40% 60% 80% 100%
6429.886 7440.040 7512.871 7570.580 7611.161 7638.599
Ticket URL: <http://trac.osgeo.org/grass/ticket/359&gt;
Resolution: | Keywords: r.quantile
  Platform: Linux | Cpu: x86-32
Comment (by dylan):
Oops. Looks like the attachment is too big. It can be accessed here:
http://169.237.35.250/~dylan/temp/beam_150.gz
Ticket URL: <http://trac.osgeo.org/grass/ticket/359#comment:1&gt;
Comment (by glynn):
Replying to [ticket:359 dylan]:
distribution, incorrect values are returned with the default number of
bins. Reducing the number of bins seems to correct the problem
[snip]
I cannot reproduce this. I always get the second set of values regardless
of the number of bins used:
$ for n in 1 2 3 4 5 6 7 8 9 10 100 1000 10000 100000 1000000 ; do
r.quantile beam_150 quantiles=5 bins=$n > quantile.$n.txt ; done
$ md5sum quantile.*.txt
2486fb3ae6eca4988acf21de10636a45 quantile.1.txt
2486fb3ae6eca4988acf21de10636a45 quantile.10.txt
2486fb3ae6eca4988acf21de10636a45 quantile.100.txt
2486fb3ae6eca4988acf21de10636a45 quantile.1000.txt
2486fb3ae6eca4988acf21de10636a45 quantile.10000.txt
2486fb3ae6eca4988acf21de10636a45 quantile.100000.txt
2486fb3ae6eca4988acf21de10636a45 quantile.1000000.txt
2486fb3ae6eca4988acf21de10636a45 quantile.2.txt
2486fb3ae6eca4988acf21de10636a45 quantile.3.txt
2486fb3ae6eca4988acf21de10636a45 quantile.4.txt
2486fb3ae6eca4988acf21de10636a45 quantile.5.txt
2486fb3ae6eca4988acf21de10636a45 quantile.6.txt
2486fb3ae6eca4988acf21de10636a45 quantile.7.txt
2486fb3ae6eca4988acf21de10636a45 quantile.8.txt
2486fb3ae6eca4988acf21de10636a45 quantile.9.txt
$ cat quantile.1.txt
Ticket URL: <http://trac.osgeo.org/grass/ticket/359#comment:2&gt;
Comment (by neteler):
Dylan, can we close this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/359#comment:3&gt;
- Reporter: dylan | Owner: grass-dev@lists.osgeo.org
- Comment (by neteler):
Hi Markus. I am getting the latest revision of 64 to check this out today.
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
      Type: defect | Status: closed
Resolution: worksforme | Keywords: r.quantile
Changes (by neteler):
  * status: new => closed
  * resolution: => worksforme
Comment:
No answer, seems to be unreproducible. Feel free to reopen.
Ticket URL: <http://trac.osgeo.org/grass/ticket/359#comment:4&gt;
Comment (by hamish):
I'd be very cautious about ignoring this one and assuming that it
magically healed itself. Silent data corruption is rather nasty when you
base other work on it.
The URL test dataset is no longer active, so I can't help test.
I wonder if "g.region rast=inputmap" might help though.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/359#comment:5&gt;
  Priority: major | Milestone: 6.5.0
Changes (by dylan):
  * milestone: 6.4.0 => 6.5.0
Comment:
Some updates: Looks like things are working now... with a similar dataset
I get the following:
in GRASS:
r.quantile in=rtk_hybrid_beam_0150 quantiles=5
Computing histogram
  100%
Computing bins
Binning data
  100%
Sorting bins
  100%
Computing quantiles
0:20.000000:7096.507812
1:40.000000:7291.034180
2:60.000000:7412.145020
3:80.000000:7514.283691
in R:
library(spgrass6)
x <- readRAST6('rtk_hybrid_beam_0150')
quantile(x@data, prob=c(0.2,0.4,0.6,0.8), na.rm=TRUE)
      20% 40% 60% 80%
7096.507 7291.034 7412.144 7514.284
Seems close enough for me. The test file is attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/359#comment:6&gt;
Comment (by dylan):
Example referenced above can be found here:
http://169.237.35.250/~dylan/temp/rtk_hybrid_beam_0150.asc.gz
Ticket URL: <https://trac.osgeo.org/grass/ticket/359#comment:7&gt;
