[GRASS-dev] [GRASS GIS] #3595: d.rast.edit: entering new value requires ENTER to be hit, GUI should be changed
changed
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.2
Component: wxGUI | Version: svn-releasebranch74
Keywords: d.rast.edit | CPU: Unspecified
Platform: Unspecified |
d.rast.edit requires ENTER key to be hit when entering a New value". This
is surprising and undocumented (and not obvious at all from the GUI).
Suggestion: change GUI behaviour to e.g. "zscale" value management of
r.slope.aspect (or any other module).
In addition, two errors come up when using d.rast.edit:
# at startup:
scripts/d.rast.edit:211: wxPyDeprecationWarning: Call to deprecated item.
   self.SetVirtualSizeHints(50, 50)
# when saving
WARNING: No data base element files found
Ticket URL: <https://trac.osgeo.org/grass/ticket/3595&gt;
changed
Resolution: | Keywords: d.rast.edit
Changes (by neteler):
* Attachment "d_rast_edit.png" added.
d.rast.edit GUI
