[GRASS-dev] [GRASS GIS] #3597: r.to.vect.tiled: parallelize tile by tile
Reporter: mlennert | Owner: grass-dev@…
Priority: minor | Milestone:
Component: Addons | Version: unspecified
Keywords: r.to.vect.tiled | CPU: Unspecified
Platform: Unspecified |
It would be great if the addon r.to.vect.tiled were parallelized to run
tile by tile on as many parallel processes as the user proposes. From a
perfunctory reading of the code, this would probably entail changing the
way the region is redefined for each tile to rather use something like
gscript.use_temp_region(). Or some version of !GridModule(), redefining
the patch() function of the class to patch vector output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3597&gt;
