#36: v.generalize Assertion failed.
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
(gdb) run -r input=cont_4144@PERMANENT output=cont_4144_general type=line
method=hermite threshold=3 look_ahead=7 reduction=50 slide=0.5
angle_thresh=3 degree_thresh=0 closeness_thresh=0 betweeness_thresh=0
alpha=1.0 beta=1.0 iterations=1 layer=1 --overwrite
Starting program: /home/maris/soft/grass_trunk/dist.x86_64-unknown-linux-
gnu/bin/v.generalize -r input=cont_4144@PERMANENT output=cont_4144_general
type=line method=hermite threshold=3 look_ahead=7 reduction=50 slide=0.5
[Thread debugging using libthread_db enabled]
[New Thread 0x2b33d27a2ce0 (LWP 16093)]
WARNING: Vector map <cont_4144_general> already exists and will be
overwritten
Generalization (hermite)...
100%
Building topology for vector map <cont_4144_general>...
Registering lines: v.generalize: index.c:157: RTreeInsertRect: Assertion
`r->boundary[i] <= r->boundary[3+i]' failed.
Program received signal SIGABRT, Aborted.
[Switching to Thread 0x2b33d27a2ce0 (LWP 16093)]
0x00002b33cf082b45 in raise () from /lib64/libc.so.6
(gdb) bt
#0 0x00002b33cf082b45 in raise () from /lib64/libc.so.6
#1 0x00002b33cf0840e0 in abort () from /lib64/libc.so.6
#2 0x00002b33cf07c07f in __assert_fail () from /lib64/libc.so.6
#3 0x00002b33ce27df3e in RTreeInsertRect (R=<value optimized out>,
Tid=<value optimized out>, Root=0x7fffddb5fa50, Level=0)
at index.c:157
#4 0x00002b33ce075559 in dig_spidx_add_line (Plus=0x7fffddb5f840,
line=12, box=0x7fffddb5f5b0) at spindex.c:128
#5 0x00002b33ce071561 in dig_add_line (plus=0x7fffddb5f840, type=2,
Points=0x74ad50, offset=105753) at plus_line.c:133
#6 0x00002b33cd177cab in Vect_build_nat (Map=0x7fffddb5f830, build=4,
msgout=0x2b33cf391760) at build_nat.c:501
#7 0x00002b33cd1767a3 in Vect_build_partial (Map=0x7fffddb5f830, build=4,
msgout=0x2b33cf391760) at build.c:152
#8 0x0000000000404e23 in main (argc=19, argv=0xfffffffe) at main.c:489
OS: OpenSuSE 10.3 64bit
GRASS: svn-trunk rev. 29954
Ticket URL: <http://trac.osgeo.org/grass/ticket/36>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
