GDAL
July 4, 2018, 6:57pm
21
#3600: m.nviz.image doesn't produce any output
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Changes (by hellik):
* Attachment "mnviz_ppm.txt" added.
winGRASS DEBUG=3 ppm
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
July 4, 2018, 6:58pm
22
* Attachment "mnviz_tif.txt" added.
winGRASS DEBUG=3 tif
GDAL
July 4, 2018, 7:08pm
23
Comment (by hellik):
Replying to [comment:18 hellik]:
> Replying to [comment:13 hcho]:
> > I think that this issue is platform dependent.
> what I get in winGRASS
some other (maybe) related tickets:
#2114
#2175
#2175
#2998
#3041
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:19> ;
GDAL
July 4, 2018, 7:20pm
24
Comment (by hcho):
Hmm...
TIFFOpen: D:\temp\mnviz\test\elev.tif: No such file or directory.
TIFFOpen cannot create a new file? Permission or that folder doesn't
exist?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:20> ;
GDAL
July 4, 2018, 7:29pm
25
Comment (by hcho):
Please try r72948.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:21> ;
GDAL
July 4, 2018, 7:42pm
26
Replying to [comment:20 hcho]:
> Hmm...
exist?
> I think this issue is different from the original one. He was able to
write out an output file with just the header. I think you'll be able to
see the original issue once you fix this TIFFOpen issue.
there is no permission issue as other winGRASS modules are able to write
to this folder.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:22> ;
GDAL
July 4, 2018, 7:56pm
27
Comment (by hcho):
Interesting... What is errno after fopen in lib/ogsf/gsd_img_ppm.c?
In GS_write_zoom,
#include <errno.h>
if (NULL == (fp = fopen(name, "w"))) {
fprintf(stderr, "errno %d\n", errno);
G_warning(...);
return (1);
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:23> ;
GDAL
July 4, 2018, 8:47pm
28
Comment (by cmbarton):
Replying to [comment:16 hcho]:
> Or in your m.nviz.image command, change {{{size=500,500}}} to
{{{size=512,512}}}.
I just did this and it gives the same result, an image file with header
but no content. Same output message too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:24> ;
GDAL
July 4, 2018, 9:05pm
29
Comment (by hcho):
Replying to [comment:24 cmbarton]:
{{{size=512,512}}}.
What about changing {{{GL_TEXTURE_2D}}} to {{{GL_TEXTURE_RECTANGLE_EXT}}}
in lib/nviz/render.c? You're on MacOS, right?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:25> ;
GDAL
July 4, 2018, 9:48pm
30
If I do that, I'll need to recompile. I'm at home today due to the
holiday. I could try this once I'm back in my office.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:26> ;
GDAL
July 5, 2018, 1:33am
31
Comment (by guano):
I made the changes to render.c:
aglCreatePBuffer(width, height, GL_TEXTURE_RECTANGLE_EXT, GL_RGBA, 0,
&(rwin->windowId));
if (aglCreatePBuffer(width, height, GL_TEXTURE_RECTANGLE_EXT, GL_RGBA, 0,
&(rwin->windowId)) == GL_FALSE)
fprintf(stderr, "aglCreatePBuffer failed: %d %d %d\n", width, height,
aglGetError());
and tried to run with {{{size=500,500}}} and {{{size=512,512}}}
the result is the same, as well as the error message:
{{{aglCreatePBuffer failed: 500 500 10005}}}
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:27> ;
GDAL
July 7, 2018, 7:32pm
32
Replying to [comment:21 hcho]:
> Please try r72948.
tested with
GRASS version: 7.5.svn
GRASS SVN revision: r72959
Build date: 2018-07-06
Build platform: x86_64-w64-mingw32
GDAL: 2.2.4
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
ppm and tif can't be opened.
DEBUG=3 output of the cmd, tif and ppm attached
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:28> ;
GDAL
July 7, 2018, 7:33pm
33
* Attachment "winGRASS_mnviz_image_tif.txt" added.
GDAL
34
* Attachment "winGRASS_mnviz_image_ppm.txt" added.
GDAL
July 7, 2018, 7:34pm
35
* Attachment "elev_winGRASS.ppm" added.
GDAL
36
* Attachment "elev_winGRASS.tif" added.
GDAL
July 8, 2018, 6:54am
37
Comment (by hcho):
Replying to [comment:28 hellik]:
> > Please try r72948.
> tested with
> GDAL: 2.2.4
> PROJ.4: 4.9.3
> GEOS: 3.5.0
> SQLite: 3.17.0
> Python: 2.7.14
> wxPython: 2.8.12.1
Hmm... The size of the ppm is 6618224*0. OK, glViewport never gets called
unless you resize the viewport. I think omitting glViewport is
implementation dependent. Please try the attached patch
(lib/nviz/render.c).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:29> ;
GDAL
July 8, 2018, 6:55am
38
Changes (by hcho):
* Attachment "lib-nviz-render.c.diff" added.
Test patch for lib/nviz/render.c (call glViewport)
GDAL
July 8, 2018, 3:51pm
39
Replying to [comment:29 hcho]:
> > > Please try r72948.
> > tested with
> > GDAL: 2.2.4
> > PROJ.4: 4.9.3
> > GEOS: 3.5.0
> > SQLite: 3.17.0
> > Python: 2.7.14
> > wxPython: 2.8.12.1
called unless you resize the viewport. I think omitting glViewport is
No chance to build winGRASS here in the next days; submitting to trunk?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:30> ;
GDAL
July 8, 2018, 5:41pm
40
I'd like to test on the Mac if I can get trunk to compile without errors.
I'll try again with a fresh checkout when I'm back at my office computers
this coming week.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:31> ;
