[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
Here is a question to the memory of the dev group. Does anyone know if m.nviz.image has *ever* worked for Mac or Windows?
If it has, any idea when it last worked? We could do a diff of the last working code and the current code to see what has changed.
If not, it may take considerable effort to make this work.
Trying to figure out an efficient way forward
Michael
______________________________
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
                                http://www.public.asu.edu/~cmbarton
On 7/12/18, 12:00 PM, "grass-dev on behalf of grass-dev-request@lists.osgeo.org" <grass-dev-bounces@lists.osgeo.org on behalf of grass-dev-request@lists.osgeo.org> wrote:
    Date: Thu, 12 Jul 2018 14:41:08 -0000
    To: undisclosed-recipients: ;
    Cc: grass-dev@lists.osgeo.org
    Subject: Re: [GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't
      produce any output
    Message-ID: <055.8e71a8cfc36b4251baa0dfd416694c92@osgeo.org>
    Content-Type: text/plain; charset="utf-8"
      Reporter: guano | Owner: grass-dev@…
          Type: defect | Status: new
      Priority: normal | Milestone:
    Component: Default | Version: 7.0.4
    Resolution: | Keywords:
           CPU: Unspecified | Platform: MacOSX
    Comment (by hcho):
    Replying to [comment:61 hellik]:
    > Replying to [comment:60 hcho]:
    > > Replying to [comment:58 hellik]:
    > > > Replying to [comment:54 hcho]:
    > > > > Only Windows defines double buffering; that's why Linux works
    without buffer swapping because it has only one buffer. BUT, glGetError()
    still returns GL_INVALID_OPERATION according to
    https://urldefense.proofpoint.com/v2/url?u=https-3A__www.khronos.org_registry_OpenGL-2D&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=BQAjtkxyihbnoyMfjeRJrNPso08jamSBCdnDLkAxL3w&s=MMgJ_nuxOOyqQYovZ_chgzuhRPYj6z2kgBDetoMH3lo&e=
    Refpages/gl4/html/glReadBuffer.xhtml. Probably, that's why some Linux
    drivers and MacOS don't work at all.
    > > > > Windows is also broken because nviz draws to the back buffer, but
    it reads from the front buffer without buffer swapping.
    > > > tested with
    > > > GRASS version: 7.5.svn
    > > > GRASS SVN revision: r72969
    > > > Build date: 2018-07-10
    > > > Build platform: x86_64-w64-mingw32
    > > > GDAL: 2.2.4
    > > > PROJ.4: 4.9.3
    > > > GEOS: 3.5.0
    > > > SQLite: 3.17.0
    > > > Python: 2.7.14
    > > > wxPython: 2.8.12.1
    > > > Platform: Windows-10-10.0.17134 (OSGeo4W)
    > > r72974+ has double buffering. Earlier version was incomplete without
    buffer swapping for Windows. Please try r72974+ later.
    > winGRASS building is broken:
    > see
    [https://urldefense.proofpoint.com/v2/url?u=https-3A__wingrass.fsv.cvut.cz_grass75_x86-5F64_logs_log-2Dr72978-2D191_error.log&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=BQAjtkxyihbnoyMfjeRJrNPso08jamSBCdnDLkAxL3w&s=9pi8B6qe-k9ydWDaw-7-RwSFI1qv0CruWCXBK3Xv2No&e=
    error.log]
    > GRASS GIS 7.5.svn r72978 compilation log
    > Started compilation: Wed Jul 11 15:02:16 2018
    > Errors in:
    > /c/msys64/usr/src/grass_trunk/lib/ogsf
    > /c/msys64/usr/src/grass_trunk/lib/nviz
    > /c/msys64/usr/src/grass_trunk/misc/m.nviz.image
    > In case of errors please change into the directory with error and run
    'make'.
    > If you get multiple errors, you need to deal with them in the order they
    > appear in the error log. If you get an error building a library, you
    will
    > also get errors from anything which uses the library.
    > Finished compilation: Wed Jul 11 15:35:12 2018
    > and
    [https://urldefense.proofpoint.com/v2/url?u=https-3A__wingrass.fsv.cvut.cz_grass75_x86-5F64_logs_log-2Dr72978-2D191_package.log&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=BQAjtkxyihbnoyMfjeRJrNPso08jamSBCdnDLkAxL3w&s=4izwLxDNf7iN91JfrST9nNeArD1BThMVT6inDjH7SZE&e=
    compiling log]
    Replaced wingdi.h with windows.h in r72980. Copied from nviz.h. Weird,
    according to Wingdi.h header - Win32 apps | Microsoft Learn
    /nf-wingdi-swapbuffers, SwapBuffer is defined in wingdi.h.
    Ticket URL: <#3600 (m.nviz.image doesn't produce any output) – GRASS GIS;
    GRASS GIS <https://urldefense.proofpoint.com/v2/url?u=https-3A__grass.osgeo.org&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=BQAjtkxyihbnoyMfjeRJrNPso08jamSBCdnDLkAxL3w&s=DCw1mza9VtQsatUpDpGWD5mTschoG4p8DvOqiEU6Z6o&e=&gt;
On Thu, Jul 12, 2018 at 5:48 PM, Michael Barton <Michael.Barton@asu.edu>
Just for the record: m.nviz.image (most probably) never worked on Windows.
On Mac (and Linux) it worked, but since certain version of operating
system(s) and/or hardware it stopped working. It was reported to work even
now (before the fixes) on an old (not updated) Mac. (In other words, the
code was not broken on the way, but still needed/needs to be fixed.)
For the future readers of this:
https://trac.osgeo.org/grass/ticket/2114
https://trac.osgeo.org/grass/ticket/2998
https://trac.osgeo.org/grass/ticket/3600
https://trac.osgeo.org/grass/ticket/3606
https://trac.osgeo.org/grass/changeset/72939
https://trac.osgeo.org/grass/changeset/72948
https://trac.osgeo.org/grass/changeset/72970
https://trac.osgeo.org/grass/changeset/72972
https://trac.osgeo.org/grass/changeset/72974
https://trac.osgeo.org/grass/changeset/72980
https://trac.osgeo.org/grass/changeset/72986
https://trac.osgeo.org/grass/changeset/72987
https://trac.osgeo.org/grass/changeset/72990
https://trac.osgeo.org/grass/changeset/72997
Sort of what I suspected. So the code is not really “broken”. But we’re trying to have it work cross platform.
Michael
Michael Barton
School of Human Evolution &Social Change
…Sent from my iPad
On Jul 19, 2018, at 7:13 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
On Thu, Jul 12, 2018 at 5:48 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Here is a question to the memory of the dev group. Does anyone know if m.nviz.image has ever worked for Mac or Windows?
Just for the record: m.nviz.image (most probably) never worked on Windows. On Mac (and Linux) it worked, but since certain version of operating system(s) and/or hardware it stopped working. It was reported to work even now (before the fixes) on an old (not updated) Mac. (In other words, the code was not broken on the way, but still needed/needs to be fixed.)
On Thu, Jul 19, 2018 at 10:12 PM, Vaclav Petras <wenzeslaus@gmail.com>
r72997 fixed m.nviz.image on Windows 10 64-bit. The off-screen bitmap
buffer never seemed to work, so I changed it to an invisible window DC,
which also supports hardware acceleration unlike a memory DC.
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
Senior Geospatial Engineer, MapAnything
Open Source GIS Developer, GRASS GIS Development Team
Unfortunately it didn’t seem to fix the Mac, since r72998 produces a black image.
Michael
C. Michael Barton
USA
Date: Thursday, July 19, 2018 at 8:17 PM
To: Vaclav Petras wenzeslaus@gmail.com
Cc: Michael Barton Michael.Barton@asu.edu, GRASS developers list grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn’t produce any output
On Thu, Jul 19, 2018 at 10:12 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
r72997 fixed m.nviz.image on Windows 10 64-bit. The off-screen bitmap buffer never seemed to work, so I changed it to an invisible window DC, which also supports hardware acceleration unlike a memory DC.
Michael, one thing weird is with no changes to the Mac code, it worked on my 10.12 Sierra VM yesterday. Maybe, VM vs. real hardware?
Huidae
Huidae Cho, Ph.D., P.E. (MD), M.ASCE, CFM, GISP
Sent from my phone
Michael
C. Michael Barton
USA
To: Vaclav Petras <wenzeslaus@gmail.com>
Cc: Michael Barton <Michael.Barton@asu.edu>, GRASS developers list <grass-dev@lists.osgeo.org>
Maybe, we can try the same thing I did for Windows. Create and hide a real window and draw to it?
Sent from my phone
Huidae
Sent from my phone
Michael
C. Michael Barton
USA
I don’t know how to add that to the C code but I can compile and test it.
Michael
C. Michael Barton
USA
Date: Friday, July 20, 2018 at 10:19 AM
To: Michael Barton Michael.Barton@asu.edu
Cc: Vaclav Petras wenzeslaus@gmail.com, GRASS developers list grass-dev@lists.osgeo.org
Sent from my phone
Huidae
Sent from my phone
Michael
C. Michael Barton
USA
For anyone who wants to try this patch on macOS.
(attachments)
include-nviz.h.diff (1.25 KB)
lib-nviz-render.c.diff (5.12 KB)
lib-ogsf-gsd_prim.c.diff (1.8 KB)
lib-ogsf-gsd_view.c.diff (675 Bytes)
Test run for the NC sample dataset.
g.region rast=elevation
m.nviz.image elevmap=elevation output=elev format=tif persp=10 --o
---------- Forwarded message ----------
Date: Sun, Jul 22, 2018 at 1:41 AM
To: Michael Barton <Michael.Barton@asu.edu>
Michael,
Please try this patch.
cd grass_trunk
for i in ~/*.diff; do
patch -p0 < $i
done
cp include/nviz.h dist.x86_64-apple-darwin17.0.0/include/grass/nviz.h
echo “#define OPENGL_FBO 1” > dist.x86_64-apple-darwin17.0.0/include/grass/config.h # case 4 below
(cd lib/nviz; make)
(cd lib/ogsf; make)
I tried AGL and CGL with/without framebuffer objects (FBO). AGL works with and without FBO, but CGL only works with FBO, again, on my VM. We know AGL without FBO doesn’t work on your mac.
  1. AGL, no FBO: OPENGL_AGL, no OPENGL_FBO in config.h works for me, but not for you.
  2. AGL, FBO: OPENGL_AGL, OPENGL_FBO in config.h works for me.
  3. CGL, no FBO: no OPENGL_AGL, no OPENGL_FBO in config.h doesn’t work for me.
  4. CGL, FBO: OPENGL_FBO, no OPENGL_AGL in config.h works for me.
If you don’t mind, please try cases 2-4.
Best,
Huidae
