[GRASS-dev] [GRASS GIS] #3603: Trunk does not compile on Mac
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone:
Component: Default | Version: svn-trunk
Keywords: calc, nviz | CPU: Unspecified
Platform: MacOSX |
I have not been able to compile GRASS trunk since last week. I did a fresh
checkout this morning to try it again with r72966. There are errors in:
/lib/nviz (new this morning)
/lib/calc (as was the case last week)
/misc/m.nviz.image (does not make because /lib/nviz does not make)
I am attaching the error output for both items. We can split ticket if
needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603&gt;
Resolution: | Keywords: calc, nviz
       CPU: Unspecified | Platform: MacOSX
Changes (by cmbarton):
* Attachment "nviz_error.txt" added.
nviz compile error
* Attachment "calc_error.txt" added.
calc compile error
Comment (by cmbarton):
Part probably related to ticket #3600
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:1&gt;
Comment (by mmetz):
Replying to [ticket:3603 cmbarton]:
fresh checkout this morning to try it again with r72966. There are errors
in:
do you have
extern func_t f_ceil;
extern func_t f_floor;
in
Applications/GRASS-7.5.app/Contents/Resources/include/defs/calc.h
and also in
Users/cmbarton/grass_source/trunk/dist.x86_64-apple-
darwin17.6.0/include/grass/defs/calc.h
needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:2&gt;
Comment (by hcho):
Replying to [comment:1 cmbarton]:
Please make sure to copy the latest include/nviz.h to your
dist.../include/grass/nviz.h
New members width and height were added to render_window struct.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:3&gt;
Replying to [comment:2 mmetz]:
in:
> do you have
> in
> and also in
Yes to both questions
needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:4&gt;
Replying to [comment:3 hcho]:
Copy from where? I have a fresh trunk checkout.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:5&gt;
Comment (by mmetz):
Replying to [comment:4 cmbarton]:
in:
> > do you have
> > in
> > and also in
This is not possible. The error message suggests:
/Applications/GRASS-7.5.app/Contents/Resources/include/grass/defs/calc.h:63:15:
note: 'f_float' declared here
         extern func_t f_float;
but f_float is now in line 65, two lines further down, because the two new
functions f_ceil and f_floor have been added. That means
is not up to date.
Why is
included at all? The location of GRASS includes at compile time should be
Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin17.6.0/include
without alternative locations.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:6&gt;
Replying to [comment:6 mmetz]:
a fresh checkout this morning to try it again with r72966. There are
errors in:
> > > do you have
> > > in
I do NOT have anything in
Applications/GRASS-7.5.app/Contents/Resources/include/defs/ because source
won't compile
> > > and also in
I do have it here
new functions f_ceil and f_floor have been added. That means
> is not up to date.
> Why is
be
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:7&gt;
Comment (by mmetz):
Replying to [comment:7 cmbarton]:
won't compile
citing from calc_error.txt posted by yourself:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:8&gt;
That's the install path, but I have not been able to do a make install. I
will delete the app and try again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: calc, nviz
* status: new => closed
* resolution: => fixed
Comment:
Figure it out. Somehow make was finding the old version in the install
path. Deleting the app made it compile without errors. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:10&gt;
Comment (by mmetz):
Replying to [comment:9 cmbarton]:
I will delete the app and try again.
Why is the install path
This path
can be outdated, please also double-check
Users/cmbarton/grass_source/trunk/include
Ticket URL: <https://trac.osgeo.org/grass/ticket/3603#comment:11&gt;
