#3606: m.nviz.image produces a screenshot
Reporter: epifanio | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Display | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: Linux |
Platform: Linux Ubuntu 18.04, 64 bit
GRASS version: 7.5 trunk revision #72985
Trying to run 'm.nviz.image' from sample location "nc_basic_spm_grass7"
returns a screenshot of the active window from whre I ran the command ...
I got a black ppm when running the above command from the terminal and I
got the attached image when running the same command from the WX gui
console.
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Changes (by epifanio):
* Attachment "m.nviz.image.png" added.
This image (converted to png because of attachment size, original format:
ppm) has been generated by m.nviz.image by running the following command '
m.nviz.image elevation_map=elevation output=elev perspective=15' from the
WX Gui console.
Comment (by hellik):
Replying to [ticket:3606 epifanio]:
console.
Comment (by epifanio):
Hi, In my case, 'm.nviz.image' does produce a proper ppm file as output,
which I can open with an image viewer (e.g. gimp) but what is rendered in
that ppm is a screen grab of the software window from where the command
was issued. It seems that 'm.nviz.image' is acting like a software to make
screenshots ... (weird). In #606 the user experienced a non-readable ppm
output, the bug can be related, of course.
Comment (by hcho):
If I remove line 480 in lib/ogsf/gsd_prim.c {{{glXSwapBuffers}}}, I'm
getting a similar result. Nviz draws to the back buffer and OGSF copies
the back buffer to the front before saving an image. You might be doing
double swapping for some reason. Please try the following patch.
Comment (by hcho):
Replying to [comment:4 epifanio]:
> Applied the patch on latest trunk rev. num.: 72990
> print out the following output:
> GRASS 7.5.svn (nc_basic_spm_grass7):~ > m.nviz.image
elevation_map=elevation output=elev perspective=15 --o
> Loading raster map <elevation@PERMANENT>...
> 100%
> 100%
> Translating colors from raster map <elevation@PERMANENT>...
> 100%
> buffer: both
> buffer: both
> buffer: both
> buffer: both
> buffer: both
> buffer: both
> buffer: both
> buffer: swap
> buffer: both
> m.nviz.image complete. File <elev.ppm> created.
> My grass_trunk is configured without X11 support:
This is my output:
buffer: back
buffer: both
buffer: back
buffer: both
buffer: back
buffer: both
buffer: back
buffer: swap
buffer: back
In your case, GS_set_draw(GSD_BACK) never worked. That's weird. Please add
{{{fprintf(stderr, "draw where: %d\n", where);}}} in line 2465 in
lib/ogsf/gs2.c. GSD_FRONT 1, GSD_BACK 2, and GSD_BOTH 3 are defined in
include/ogsf.h.
Anyway, I think you need X11 support because Nviz requires some Xlib
functions (XOpenDisplay, XCreatePixmap, XFree, ...) in lib/nviz/render.c.
Please try it again with X11 support enabled. Is there any specific reason
why you disabled it?
Rebuilding with X support enabled didn't change the `m.nviz.image` output.
Adding `fprintf(stderr, "draw where: %d\n", where);`, as you instructed,
produce the following output:
(Mon Jul 16 14:19:48 2018)
m.nviz.image elevation_map=elevation output=elev perspective=15 --o
WARNING: File <elev.ppm> already exists and will be overwritten
draw where: 2
buffer: both
draw where: 3
buffer: both
draw where: 2
buffer: both
draw where: 3
buffer: both
draw where: 2
buffer: both
draw where: 3
buffer: both
draw where: 2
buffer: both
buffer: swap
draw where: 2
buffer: both
(Mon Jul 16 14:19:48 2018) Command finished (0 sec)
Comment (by hcho):
Replying to [comment:6 epifanio]:
output.
> draw where: 2
> buffer: both
> draw where: 3
> buffer: both
> draw where: 2
> buffer: both
> draw where: 3
> buffer: both
> draw where: 2
> buffer: both
> draw where: 3
> buffer: both
> draw where: 2
> buffer: both
> buffer: swap
> draw where: 2
> buffer: both
Could you please attach your lib/ogsf/gs2.c, lib/ogsf/gsd_prim.c, and
include/ogsf.h? I know they must be the same as my trunk, but looks like
switch doesn't work at all? I'm confused.
I think I know what happened. In gsd_prim.c, all gsd_bothbuffers,
gsd_frontbuffer, and gsd_backbuffer have "buffer: both\n". That's why I
was confused. Anyway, that's not the reason for your problem.
Comment (by hcho):
Maybe try size=100,100 and see what the output size is.
Not sure what it is, but you can also try to directly draw to the front
buffer without buffer swapping
1. Change line 223 in lib/nviz/draw.c to {{{GS_set_draw(GSD_FRONT);}}}
2. Comment out line 480 {{{glXSwapBuffers}}} from lib/ogsf/gsd_prim.c.
@hco The two changes you proposed fixed the issue. I didn't test all the
`m.nviz.image` options, but I can now render a proper elevation map with
no errors.
Comment (by hcho):
Replying to [comment:12 epifanio]:
> forgot to say, ... Thanks for your help!!!
You're welcome and thanks for testing, but it only solves your specific
problem. I still don't understand why drawing to the back buffer and
swapping it to the front doesn't work for you. Could you please try one
more thing?
1. Change line 223 in lib/nviz/draw.c to {{{GS_set_draw(GSD_BOTH);}}}
2. Uncomment line 480 {{{glXSwapBuffers}}} in lib/ogsf/gsd_prim.c
So the only different from trunk is {{{GS_set_draw(GSD_BOTH);}}} vs
{{{GS_set_draw(GSD_BACK);}}}.
Comment (by hcho):
Replying to [comment:15 epifanio]:
> Double checking I've the right changes applied to the right files, here
is a gist of the previous files:
> https://gist.github.com/c6a7cb6019f2347add44f2dc6b35f4c7
> With this configuration, I do have a proper PPM rendering the elevation
surface correctly.
I'm confused. Do you mean that the files in the gist work for you? That's
basically trunk + debug outputs.
In your last test, you drew to the front buffer without swapping
(different from your gist). Did they both work for you?
Comment (by hcho):
Replying to [comment:14 cmbarton]:
> When this is at a point where it seems to be working on Windows, let me
know and I'll recompile it for the Mac and test some more.
